Kinetic/Potential Energy and Work help
  • Thread starter Thread starter xx3dgxx
    Energy Work
The discussion revolves around calculating kinetic energy, gravitational potential energy, and work done by gravity for a baseball thrown at a specific speed and angle. The kinetic energy of the ball as it leaves the player's hand is calculated to be 151.9J, and at its highest point, it is 101.9J. The participant is unsure about calculating the work done by gravity and assumes it to be 50J based on the change in kinetic energy. To find the maximum height, they suggest using the gravitational potential energy formula, leading to an estimated height of 34m. The conversation emphasizes the importance of understanding the signs of work done by gravity in relation to the direction of motion.
xx3dgxx
A baseball outfielder throws a 0.15kg ball at 45m/s at an initial angle of 35°.
a) What is the kinetic energy of the ball as it leaves the player's hand?
b) What is the kinetic energy of the ball at its highest point of trajectory?
c) Gravity is the only force acting on the ball as it moves to the highest point. How much work did gravity do?
d) How high is the ball?
(C and D must use the work energy theorem)
Kinetic energy = (1/2)mv2
Grav. potential energy = mgΔy
Work = FΔrcosθ
I'm pretty confident on parts A and B, C and D are where I'm slightly confused
a) (1/2)mv2 = 0.5 * .15kg * 45m/s2 = 151.9J
b) 0.5 * .15kg * (45cos(35°))2 = 101.9J
c) I'm not sure where to go mathematically from here, because I don't know the max height, and the only equation I can think of requires it.
I assume the work done by gravity is 50J though, because from part a and b, the change in kinetic was -50, and that'd have to change to grav. potential energy.
If C was correct at 50, this is how I'd think to do D.
d) Grav potential(U) = mgΔy
U/mg = Δy = 50/(.15*9.8) = 34m
If someone can check all my work and explain what's wrong, that'd be great! Thank you!
Welcome to forum
Yes you are right
Work done by a force is ∫F.ds, where all vectors must be measured in the same sense. If the force, gravity, acts down and the distance moved is up, what sign would the work done have?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
