Kirchhoff's Junction Rule in the AC case....
In summary, Kirchhoff's laws are valid for both DC and AC circuits, but they may only be approximations at high frequencies. In an AC circuit, it is possible for zero current to exit a node, even though multiple currents are entering. This is due to the fact that the AC currents in complex vector form add up to zero. The net current exiting the node being zero does not mean there is charge accumulation or a lack of instantaneous velocity, but rather that the currents are cancelling each other out. This applies to both AC circuits with sine waves and three-phase systems.
fog37
1,568
108
Kirchhoff's laws are valid for DC circuit and also for AC circuits (up to point. I think they become only approximations at high frequencies).
Let's consider a node (junction) in a AC circuit. Three AC currents with the same magnitude but different relative phases enter the node. It is possible for zero current to exit the node, correct? It seems strange though that 3 currents enter and no current leaves the node. That cannot happen in DC: no charge accumulation can happen at any point in the circuit.
But what does it physically mean that in the AC case the net current exiting the node is zero? That there is some charge accumulation and that the charge does not have an instantaneous velocity at that point? thanks!
There is no mystery. The currents (in complex vector form) simply add up to zero.
Consider a DC wire. We have a 1 amp current traveling to the left and 1 amp traveling to the right. They add up to zero; no current. Why is that mysterious?
But what does it physically mean that in the AC case the net current exiting the node is zero? That there is some charge accumulation and that the charge does not have an instantaneous velocity at that point?thanks!
Lets
For simplicity let's assume the AC current is a sine wave with a magnitude of 1V and a frequency of 1 Hz.
The voltage waveform will start at zero, increase to 1, decrease to 0, decrease to -1, etc...
so if our AC signal is going into an element, the actual instantaneous current going into the element is going to switch between positive and negative.
also don't forget that sin(x)= -sin(ft+180)
if we have two signals waves A and B
A=sin(ft)
B=sin(ft+180)
you can say that both signals go into an element from different directions.Does that make sense?
When you're dealing with circuitry like this, thinking of the velocity of charge is going to confuse the hell out of you. Think of it at a higher level unless for some reason you need to look into it with that level of complexity.
Also a third way of saying the same thing, for three phase systems.
What is the numerical value of COS(0)+COS(2*pi/3)+cos(-2*pi/3)? All angles are in radians.
Hello,
sure, COS(0)+COS(2*pi/3)+cos(-2*pi/3)=0. It is as if three mono-phase generators where connected together Superposition)
Related to Kirchhoff's Junction Rule in the AC case....
1. What is Kirchhoff's Junction Rule in the AC case?
Kirchhoff's Junction Rule, also known as Kirchhoff's Current Law, states that the sum of all currents entering and leaving a junction in an electrical circuit must equal zero. This applies to circuits with alternating current (AC) as well.
2. How is Kirchhoff's Junction Rule used in AC circuits?
In AC circuits, Kirchhoff's Junction Rule is used to determine the flow of current at different points in the circuit. It helps to calculate the unknown currents and voltages by considering the conservation of charge at a junction.
3. What is the significance of Kirchhoff's Junction Rule in AC circuits?
Kirchhoff's Junction Rule is an essential law in circuit analysis, as it helps to analyze complex AC circuits and understand the flow of current. It also allows us to predict the behavior of different components in the circuit, such as resistors, capacitors, and inductors.
4. Can Kirchhoff's Junction Rule be applied to all types of AC circuits?
Yes, Kirchhoff's Junction Rule can be applied to all types of AC circuits, including series, parallel, and combination circuits. It is a fundamental principle in circuit analysis and is used extensively in electrical engineering and physics.
5. What happens if Kirchhoff's Junction Rule is violated in an AC circuit?
If Kirchhoff's Junction Rule is violated in an AC circuit, it would indicate an error in the circuit analysis or a faulty circuit design. The violation of this rule means that the conservation of charge is not being followed, leading to inaccurate calculations and predictions about the circuit's behavior.
