MHB Kylie's question at Yahoo Answers regarding minimizing the area of a triangle
  • Thread starter Thread starter MarkFL
    Area Triangle
Kellie's problem involves minimizing the area of a triangle cut from a rectangular scarf to remove a burn located at (2,5). By positioning the scarf's corner at the origin and using the two-intercept form of a line, the area of the triangle is expressed as a function of its x-intercept, b. The area function is derived as A(b) = (5b^2)/(2(b-2)), and by differentiating and finding critical points, it is determined that the minimum area occurs at b = 4. The smallest area of the triangular piece that can be cut off to eliminate the burn is 20 cm².
MarkFL
MHB
Here is the question:
Kellie discovers a burn in her new scarf. She decides the best solution is to cut off one corner of the scarf?
The scarf is a rectangle and the burn is located 2cm from one edge and 5 cm from a perpendicular edge, what is the smallest area of the triangle she has to cut off to remove the burn?
using optimization!
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello kylie,
Let's orient our coordinate axes such that one corner of the scarf is at the origin and the burn is at the point $(2,5)$. The cut Kellie makes will lie along the line having $x$-intercept $(b,0)$ and $y$-intercept $(0,h)$, and must pass through the point at which the burn is located.
Using the two-intercept form for a line and the point at which the burn is located, we obtain the constraint:
$$\frac{2}{b}+\frac{5}{h}=1$$
Solving for $h$, we find:
$$h=\frac{5b}{b-2}$$
The area $A$ of the triangular portion of the scarf that is removed is:
$$A=\frac{1}{2}bh$$
Substituting for $h$, we obtain the area as a function of $b$ alone:
$$A(b)=\frac{b}{2}\left(\frac{5b}{b-2} \right)=\frac{5b^2}{2(b-2)}$$
Differentiating with respect to $b$ and equating the result to zero, we obtain:
$$A'(b)=\frac{2(b-2)(10b)-5b^2(2)}{(2(b-2))^2}=\frac{5b(b-4)}{2(b-2)^2}=0$$
Observing that we require $$2<b$$ we obtain the critical value:
$$b=4$$
Observing also that to the left of this critical value $A'(b)<0$ and to the right $A'(b)>0$, the first derivative tells us the critical value is at a minimum.
Hence:
$$A_{\min}=A(4)=20$$
Thus, the smallest triangular piece of scarf that Kellie can remove has an area of $20\text{ cm}^2$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
