LAB: Bragg Diffraction Grazing Angle Error
The discussion revolves around understanding how to calculate the uncertainty in the grazing angle during a Bragg diffraction experiment using microwaves. The original poster is confused about how to relate the uncertainty in voltage measurements, taken from an oscilloscope, to the uncertainty in the grazing angle. It is clarified that the voltage reflects the intensity of the scattered microwaves and that both angle and voltage contribute to the overall uncertainty. Suggestions include fitting a function to the voltage peak to determine the angle more accurately, while also considering both statistical and systematic uncertainties. The conversation emphasizes the need to integrate multiple sources of uncertainty for precise measurements in the experiment.
Gemini_Cricket
I wasn't sure where to post this question. I hope I picked the right section of the forums. This is from intermediate lab. The lab is for Bragg diffraction using microwaves. The grazing angle is a measured quantity along with the voltage (which was measured using an oscilloscope). The uncertainty on the voltage is estimated. The grazing angle that is recorded is from the angle indicated on the turntable disk that the reflection cube (crystal) sits on.
Not sure if the Bragg equation is needed but here it is:
n*(wavelength) = 2*(plane spacing)*sin(grazing angle)
Okay, so I assumed that the uncertainty in the grazing angle would be the uncertainty in the measurement, however my professor told me to measure the error in the angle by the error in the voltage. I have no idea what he means by this. I know about error propagation and the different equations, but have no clue how to use the error in the voltage and translate that to error in the angle.
One data set is 3 degrees at a voltage of 290 +/- 1. Any ideas?
Please describe the whole setup.
Which voltage? What does that voltage mean?
Okay I'll try to make it short. There's a microwave transmitter, it transmits microwave radiation onto a foam cube of steel chrome balls that act as scattering centers. There is a receiver on the other side that picks up the radiation after it is reflected. The turntable that the cube sits on can be rotated at specific angle intervals. Data is recorded for a number of angles. The voltage is as measured by the oscilloscope. The peaks in the voltage correspond to the maximum reflection angles. Since the grazing angles are measured directly I would think that the uncertainty would just be human measurement error, but apparently that is not the case.
Ah, so voltage is a measurement of the reflected intensity for a given angle. Well, then you have two sources of uncertainty, the angle and the voltages. If there is a reasonable peak visible in the data, I think I would fit a function to that peak, otherwise I would estimate the peak position in some other way (depends on the setup then). This will include both the statistic uncertainty for the angle and the uncertainty for the voltage, and then the systematic uncertainty for the angle can be added afterwards.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
