Engineering LabVIEW Opamp Circuit Homework Solution with USB6008 Measurements
  • Thread starter Thread starter Shaq Melbourne
    Circuit Opamp
The discussion focuses on a homework assignment involving the construction of an I-V characteristic circuit using a USB6008 for floating source measurements. The user has shared their LabVIEW script and circuit image, indicating progress on the task. There was an initial issue with file format compatibility that prevented the sharing of the actual LabVIEW file. The conversation highlights the importance of providing clear documentation of work in homework submissions. Overall, the user is seeking feedback on their circuit design and measurements.
Shaq Melbourne
The task States to build the I-V characteristic circuit where AIa and AIb are floating source measurements taken with the USB6008 and VS is supplied by
the voltage follower circuit.
I've also attached the actual script, for added context.
I've attached the LabVIEW file of my attempt, which is a follow up from the first task, which I've been told is correct.
Welcome to the PF. :smile:
I'm not seeing your work on the problem...
My apologies, when attaching the it said it was an unsupported file format, so I attached a picture of the LabVIEW circuit I made. I've made some progress which is seen in the following picture.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
9K
