fluidistic
- 262
Not really a homework question, just want to check out if what I'm doing is right. I challenged myself to find the equation of motion and the forces in the simple pendulum system but with using the Lagrange multipliers and the constraint equation.
In next part.
Let [itex]l[/itex] be the length of the pendulum. I use polar coordinates and set my system of reference in the place where the mass is when at rest. The constraint equation is, I believe, [itex]l=\text{constant}=C[/itex].
I write a modified Lagrangian which takes into account the constraint equation and the Lagrange multiplier. [itex]\tilde L =L-\lambda _ l (l-C)[/itex].
The kinetic energy of the system is [itex]T=\frac{m\dot \theta ^2 l^2}{2}[/itex] while the potential energy is [itex]V=l-l\cos \theta[/itex].
So that [itex]\tilde L=\frac{m\dot \theta ^2 l^2}{2}-(l-l\cos \theta)-\lambda _ l (l-C)[/itex]. I have thus 3 "generalized coordinates", [itex]\lambda _l[/itex] which should be worth the force of constraint, theta and [itex]l[/itex].
Euler-Lagrange equations yield [itex]l=C[/itex] when considering [itex]\lambda_l[/itex] as generalized coordinate, [itex]\theta ^2 +\frac{g}{l}\sin \theta =0[/itex] where I had to consider that [itex]l=C[/itex] so that [itex]\dot l=0[/itex] (that was when considering theta as generalized coordinate) and finally for [itex]l[/itex] they yield [itex]\lambda _l=m \dot \theta ^2 l -mg (1+\cos \theta )[/itex] which has units of Newton. So I am guessing this is the tension force or something like that, I am not really sure. This is a generalized force but I'm not sure with respect to what generalized coordinate. Any explanation is appreciated.
I wonder if all I did is ok. Could someone clarify things up? Thank you!
However I do not know how to get the generalized force, [itex]\lambda _l[/itex].
