Laplace transform vs phasor analysis in circuit analysis
Laplace transform and phasor analysis are interconnected, with the former encompassing a broader range of applications, including transient and steady-state solutions. While phasor analysis is limited to sinusoidal steady-state conditions, the Laplace transform can incorporate initial conditions and handle impulse responses, making it a more versatile tool. When the Laplace variable s equals jω, it simplifies to phasor analysis, yielding steady-state sinusoidal solutions. The decay terms in Laplace transform solutions approach zero as time progresses, leaving only the steady-state solution. Overall, the Laplace transform is a powerful method that can also be applied to sinusoidal steady-state analysis.
Wrichik Basu
Insights Author
I recently acquainted myself with Laplace transform, and it appears that it has some relations with phasor analysis. This observation stems from the fact that while in Laplace transform, we have ##s = \sigma + j \omega## as the variable, in phasor analysis, we just use ##j\omega,## apparently just setting ##\sigma = 0.## Is there any other way the two methods are related?
I have seen phasor analysis being used only for sinusoidal steady state analysis, while Laplace transform gives the transient solution since the initial conditions are built into it, and we solve the circuit with that. Laplace transform also allows us to incorporate impulse-type voltages and currents in the circuit, wherefrom it seems to me that Laplace transform is a more powerful tool. Can Laplace transform be used to do sinusoidal steady state analysis as well? I don't see why not, but need a confirmation.
Yes, absolutely related. When s=jω, you get the steady state sinusoidal solutions, otherwise there is an exponential growth (or decay) element in the solutions. So the Laplace transform is the more general case that can be used to obtain transient and/or steady state solutions.
  • Love
Likes berkeman, DeBangis21, alan123hk and 1 other person
I will have to go through that video once again to get my brain straight, but I understood this much that if I use Laplace transform and get a decay term, then in the ##\lim_{t \rightarrow \infty}## that decay term basically ##\rightarrow 0,## so I am left with the steady state solution only. Thanks.
The two methods are related, but it depends on where the Laplace transform converges. I posted about this in a different thread awhile ago.
https://www.physicsforums.com/threa...-of-the-laplace-transform.971324/post-6174503
jason
Likes berkeman and Wrichik Basu
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
