Laplace's equation on an annulus with Nuemann BCs
  • Thread starter Thread starter nathan12343
    Laplace's equation
nathan12343
Solve Laplace's equation inside a circular annulus (a<r<b) subject to the boundary conditions \frac{\partial{u}}{\partial{r}}(a,\theta) = f(\theta)\text{, }\frac{\partial{u}}{\partial{r}}(b,\theta) = g(\theta)
Assume solutions of the form u(r,\theta) = G(r)\phi(\theta). This leads to an equation for phi and G, both of which can be solved by substitution:
<br /> \frac{d^2\phi}{{d\theta}^2} = -\lambda^2\phi<br />
<br /> \phi = A\cos{\lambda\theta} + B\sin{\lambda\theta}<br />
<br /> r^2\frac{d^2G}{{dr}^2} + r\frac{dG}{dr} - n^2G = 0<br />
<br /> G = c_{1n}r^{-n} + c_{2n}r^n\text{ for } n\ne0<br />
<br /> G = c_{10} + c_{20}\ln(r)\text{ for } n=0<br />
Periodic boundary conditions require that u and its derivative with respect to theta be continuous between -pi and pi. Then means \lambda = n for all n greater than or equal to zero. We can write,
<br /> u(r,\theta) = &amp;\, A_{01} + A_{02}\ln(r) + \sum_{n=1}^{\infty}(A_{n1}r^n + A_{n2}r^{-n})\cos{n\theta} + (B_{n1}r^n + B_{n2}r^{-n})\sin{n\theta}<br />
<br /> \frac{\partial{u(r,\theta)}}{\partial{r}} = &amp;\, A_{02}r^{-1} + \sum_{n=1}^{\infty}(nA_{n1}r^{n-1} + -nA_{n2}r^{-n-1})\cos{n\theta} + (nB_{n1}r^{n-1} - nB_{n2}r^{-n-1})\sin{n\theta} <br />
I know that I can set everything in parentheses in front of the cosines and sines above equal to some constant when I set r=a,b to enforce the boundary conditions on the edge of the annulus. This leaves me with two equations in two unknowns for all the A's and B's with n greater than 1. My problem is how to set A_{02}[/tex] such that it will work at both boundaries. It seems like I really need two constants to match to the boundary for when n=0. Am I missing something?<br /> <br /> Thanks for your help!
Can anyone help?
Really? It seems like a simple problem...
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
