Laser experiment, determine angular velocity
In summary, The distance between a spinning circular cannister of reflective liquid and the surface is given by h(r) = h(0) + (ω2/2g)r2, where g ≈ 9.82 and r is the distance to the axis of revolution. When two parallel laser beams are shined on the surface, they meet at a point 22 cm above the surface. To find ω, we can use the equation f = R/2, where R is the radius of curvature. However, it is unclear how to find the equation for a parabola given the curvature, and the attempted solution involved taking the gradient and setting up vector equations. Ultimately, the solution was found without using these methods.
Gauss M.D.
153
A circular cannister of some reflective liquid is spinning at some ω. The distance between the cannister and the surface is given by
Where g ≈ 9.82 and r is the distance to the axis of revolution. When we shine two parallell laser beams on the surface, we find that they meet at a point 22 cm above the surface.
Find ω.
f = R/2
We have a parabolic mirror with radius of curvature = 0.44 m. But I'm not really sure how to find the equation for a parabola given the curvature. I was well on my way to taking the gradient of the parabola and setting up some kind of system of vector equations, but I suspect that would be overkill...
Figured it out.
Related to Laser experiment, determine angular velocity
1. What is a laser experiment?
A laser experiment is a scientific procedure that uses a laser beam to study the properties and behavior of light. It is commonly used in physics and engineering to measure various physical quantities, such as angular velocity.
2. How is angular velocity determined in a laser experiment?
In a laser experiment, angular velocity is typically determined by measuring the displacement of a laser beam as it rotates around a central axis. This displacement can then be used to calculate the angular velocity of the rotating object.
3. What equipment is needed for a laser experiment to determine angular velocity?
The equipment needed for a laser experiment to determine angular velocity includes a laser source, a rotating platform or object, a photodetector, and a computer or data logger to record the measurements.
4. What are the applications of a laser experiment to determine angular velocity?
A laser experiment to determine angular velocity has many practical applications, such as in robotics, aerospace engineering, and navigation systems. It can also be used to study the motion of celestial bodies and to measure the rotational speed of machinery.
5. Are there any limitations to using a laser experiment to determine angular velocity?
Yes, there are some limitations to using a laser experiment to determine angular velocity. These include the precision of the equipment, external factors that can affect the measurements (such as vibrations or air currents), and potential errors in the calculations. It is important to carefully design and calibrate the experiment to minimize these limitations.
