MHB Lattice energy, hydration energy, solution energy
  • Thread starter Thread starter WMDhamnekar
    Energy Lattice
The discussion focuses on the enthalpy of solution for potassium chloride (KCl), highlighting that its dissolution is endothermic with a calculated value of +30 kJ/mol, contrasting with the standard value of -17.22 kJ/mol. Participants debate whether the temperature increases or decreases when KCl dissolves, concluding that it decreases due to the energy required for dissolution. The conversation also touches on interactions during dissolution, confirming ion-dipole interactions for calcium chloride in ethanol and dispersion forces for toluene in benzene. Additionally, the enthalpy of hydration is compared between sodium and calcium ions, with calcium having a larger absolute value, and similar reasoning is applied to potassium nitrate (KNO3), which also results in a temperature decrease upon dissolution.
WMDhamnekar
MHB
Hi,
The enthalpy of crystallization of $KCl$ (Potassium Chloride) is + 715 kJ/mol. The enthalpies of hydration for Potassium and Chloride are -322 and -363 kJ/mol respectively. So, enthalpy of solution of $KCl \Delta H_{sol}=\Delta H_{lattice} - \Delta H_{hyd}$
$\Delta H_{sol}=715 kJ/mol -685 kJ/mol= 30 kJ/mol.$
But if you see table of enthalpy of solution, it is -17.22 kJ/mol for $KCl(s).$ Obviously, our experiment value 30 kJ/mol indicates dissolving $KCl$ into water is endothermic reaction. Should the temperature increase or decrease when $KCl$ dissolves?
My answer is temperature increase when $KCl$ dissolves.
What types of interaction are present when $CaCl_2$ dissolves in ethanol($CH_3CH_2OH)$?
My answer: Ion-dipole
What is the major type of interaction when toluene$C_7H_8$ dissolves in benzene$C_6H_6?$
Answer is unknown.
Which ion has a larger absolute value of enthalpy of hydration, $Na^+$ or $Ca^{2+}$?
My answer: $Ca^{2+}$
Which ion is larger, $Na^+$ or $Cl^-?$
My answer is $Cl^-$
When $KNO_3$ is dissolving in water, will the temperature decrease or increase?
My answer:Temperature will increase.
Are my answers correct?
Mathematics news on Phys.org
Dhamnekar Winod said:
Hi,
I'm seeing slightly different numbers from different sources and I'm not sure why.
Either way, with your numbers it takes 715 kJ/mol to break the lattice, and 685 kJ/mol is released when we dissolve the ions.
The result is positive, meaning that it takes energy to dissolve $\ce{K Cl}$, which is indeed endothermic.
It takes energy to dissolve the crystal, which must come from somewhere.
It means that the temperature will decrease instead of increase.
Correct.
Answer is unknown.
This page lists it as dispersion.
My answer is $Cl^-$
You didn't explain why... but yeah, that looks correct to me.
It appears that $\ce{K NO3}$ also has a positive enthalpy of solution.
It means that the temperature will decrease as well since it takes energy to dissolve.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
