Leaving out a confounder in longitudinal regression?
In summary, while Injury Status may be a confounder, it should be included in the model if it correlates with the dependent variable.
FallenApple
566
61
Say I want to analyze how a relation changes though time. Like usual, I would throw in the potential confounders into the regression model. But what if some of the confounders are not determined at the beginning of the study but at some point within time?
For example, say I want to analyze the relation between creatine doses and sports performance over time. So a basic linear mixed model would be: ##Performance_{ij} \sim Dose_{ij}+Time_{ij}+Dose_{ij}*Time_{ij}+PotentialConfounders_{i}+RandomEffects_{i}+error_{ij}##
Where i is the ith subject and j is within that subject. Say Dose and Performance are measure longitudinally. and the rest of covariates are just recorded once and is the same for all levels within the ith subject.
Say I suspect that gender might confound the relation between creatine and performance. Well, a persons gender is fixed throughout the study.
But what about say injury? Say I have an injury indicator variable that's says whether the athlete experiences injury during the study. Where I don't know when it happened in the study. This is different from say gender, where even if the data is collected after, we know it couldn't have changed. Anyways, If I consider Injury Status as potential confounder, should I include it? I mean, it might not be present at all time points. It seems that whatever inference obtained by including it would be invalid. But then again, if injury is a confounder, then not adjusting for it would also result in invalid inferences.
So yes, you can only partially correct for confounding. Better than nothing, isn't it?
Also note that for a confounder to be a confounder, it has to correlate both with the effect and with the parameter of interest. E.g. injury may not correlate with dose (if subjects take the same dose independently of whether injured or not) but certainly correlates with time.
The inferences to draw from statistical analysis is always entirely the responsibility of the subject matter expert. One should be careful about thinking that statistics will do more than show correlation.
It should be noted that, unless a person has control of the independent variables, most independent variables will be a confounder. When a person puts a variable into a model, it is usually because he suspects some relationship or correlation between it and the dependent variable. It would be unusual for two such independent variables to not also show some correlation among themselves. So that is what procedures like stepwise multiple regression are designed to handle. The exception to this is when an experiment is specifically designed to minimize or even completely eliminate the correlation between the independent variables.
FAQ: Leaving out a confounder in longitudinal regression?
What is a confounder?
A confounder is a variable that is related to both the independent and dependent variables in a study. It can create a false association between the two variables and can impact the results of the study.
Why is it important to consider confounders in longitudinal regression?
Confounders can bias the results of a study and lead to incorrect conclusions. By including confounders in the analysis, we can better understand the true relationship between the independent and dependent variables.
How do you identify potential confounders in longitudinal regression?
Potential confounders can be identified through a literature review, theoretical understanding of the variables, and statistical tests such as correlation analysis. It is important to consider all potential confounders and include them in the analysis if they are found to be related to both the independent and dependent variables.
What methods can be used to control for confounders in longitudinal regression?
There are several methods that can be used to control for confounders in longitudinal regression, including stratification, matching, and multivariate analysis. These methods aim to adjust for the effects of the confounder and isolate the true relationship between the independent and dependent variables.
What are the potential consequences of leaving out a confounder in longitudinal regression?
If a confounder is left out of the analysis, the results may be biased and misleading. This can lead to incorrect conclusions and impact the validity of the study. It is important to carefully consider and control for confounders to ensure the accuracy of the results.
