Can a 2' Multicolor LED Strip Be Powered by Two CR2032 Batteries?
  • Thread starter Thread starter Lyyle Morgan
    Led
Running a 2' multicolor LED strip with two CR2032 batteries is not feasible due to the batteries' low current capacity and voltage output. CR2032 batteries provide 3V and a maximum continuous current of 6mA, which is insufficient for most LED strips that typically require higher voltages and currents. The batteries are designed for low-drain applications, making them unsuitable for powering LEDs for extended periods. Alternatives like Zinc-Manganese Dioxide (Zn-MnO2) batteries, or "N" cell alkaline batteries, are recommended for better performance. Overall, using CR2032 batteries for this purpose is impractical.
Lyyle Morgan
TL;DR Summary
LEDs on CR2032?
I want to run a 2' multicolor LED strip with 2 CR2032 batteries. Is this possible?
Internet rules say that writing with caps on is equivalent to yelling. Having said that, how many leds have your strip? [Note: all caps OP has been fixed by the Mentors]
What is the terminal voltage of a CR2032 button battery? What is the A*hr capacity rating of a CR2032? What is the input voltage and current specified on the datasheet for your LED strip?
Do you know how to build/use buck and boost DC-DC converters?
Not for long.
The CR series batteries are designed for very low current application with a few years usable life.
You would be better off using Zinc-Maganese Dioxide (Zn-MnO2) batteries. They are commonly called Alkaline batteries. The smallest I know of are the size "N" cell, about 30mm long x 12mm dia.
Cr2032
Lithium/Manganese Dioxide
Open Circuit: 3.0V
Max continuous Current: 6mA
Nominal Capacity: 245mAh @170uA and 2.0V cutoff
Above from:
https://www.duracell.com/wp-content/uploads/2021/06/CR2032CH_245mAh-CS.pdf
Cheers,
Tom
Thanks for the input, but I don’t have the answers to your questions. This is just a starting point to an idea I have. Just want to know if it’s even possible. Thanks again
Tom.G said:
Not for long.
Cr2032
Open Circuit: 3.0V
Above from:
Cheers,
Tom
Hi Tom. Thanks for speaking in a way I can understand. I’m looking to power the strip for a couple of hours. Just wondering if this is even possible. I’ve found a case that holds 2 CR2032s and has wires leading out. Wondering if the wires could be connected to a 2’ strip of LEDs. Thanks again for getting back to me. Lyle
The point of my questions was for you to look that information up. That is how you answer your original question of whether it is possible. :wink:
Tom.G said:
Not for long.
Cr2032
Open Circuit: 3.0V
Above from:
Cheers,
Tom
The round shape of the CR2032 is perfect for what I need. I’m not sure how I could mount the N. Thanks
I agree with Tom.G
First, in my opinion, CR 2032 supplies 3 V and Led strip requires-5 to 24 V -depending on type.
The load current for LED strips may be 2400 to 7200 mA but CR2032 capacity it is only 235 mAh that means 235/3600=0.06528 mA that means if itsupplies a 0.06528 mA load the voltage will be only 2 V [minimum level] in an hour.
CR2032 resistance Rdc≈15 kΩ and LED Strip load resistance is 3/7.2=0.417 Ω that means a short-circuit for CR2032.
