High School Leg muscles’ force as a system of levers
  • Thread starter Thread starter KataruZ98
    Force System
To break down the total force exerted by leg muscles into forces for each muscle group, one can use inverse dynamics to determine external joint torques from ground reaction forces. This process requires specifying an optimization criterion due to the problem being underdetermined. Muscle optimization techniques can then be applied to balance these external torques with the corresponding muscle forces. Software like OpenSim can facilitate this analysis, especially when simplifying the model to 2D with fewer muscles. Understanding these principles allows for a more accurate assessment of muscle force distribution in the leg.
KataruZ98
TL;DR
How can I calculate the force exerted by each muscle group in a jump?
If I know a person has exerted total force F with their legs and I’m interested in breaking down said force in smaller forces exerted for each involved muscle group - how can I do it? With a basic level of understanding of human anatomy I can divide the leg as a series of levers but how can I specifically find force exerted by each lever?
EDIT: I’m aware “smaller” is not the correct word, but still..
Note that this is an underdetermined problem, so you need to specify an optimization criterion to get a unique solution. You use inverse-dynamics to get the external joint torques from the ground reaction force, and then muscle optimization to get the muscle forces that balance these external torques.
You can use software for that:
https://simtk.org/projects/opensim
If you simplify it to 2D and just a few muscles, then you might get something that you can solve by hand.
A.T. said:
Note that this is an undermined problem, so you need to specify an optimization criterion to get a unique solution. You use inverse-dynamics to get the external joint torques from the ground reaction force, and then muscle optimization to get the muscle forces that balance these external torques.
Ah, I see. Thank you very much, I’ll see what I’ll be able to do.
A.T. said:
undermined
I suspect that the correct word is underdetermined.
There are some nasty repetitions in there to entice the fingers to skip ahead in the sequence and no spell check to save you.
Yes, thanks. Fixed it.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
