DaveC426913
- 6,398
- TL;DR Summary
- If we fire two electrons at the same time, one metre apart, should they length contract till they're less than a metre apart?
I've managed to stump myself in attempting to answer a member on another forum.
He is attempting to demonstrate length contraction using two electrons a known distance apart and moving at a known velocity.My thought experiment is based on his proposal; that's why I've chosen the components I have.
We have two parallel electron guns. Ga and Gb. Gb is one metre behind Ga and sightly offset to one side. Both are dialed down so they fire only one electron at a time.
We have two detectors, Da and Db, each 10 metres away from its gun.
To sum: , we have two identical setups, Sa, and Sb, with Sb just happening to be displaced by one metre along the direction of travel.We fire both guns simultaneously. The electrons are fired with enough energy to achieve relativistic velocities, say, 0.87c.
Electrona and Electrona leave their gun at 0.87c, and travel to their detector 10m away.
The detectors should light up at exactly the same time. Right?
OK, now I add a bit of magic. I use a piece of nigh-infinitely thin, nigh-infinitely light wire "tied" to both electrons. We now have a stick that is one metre long. We repeat the experiment: and both ends of the stick have been accelerated to .87c.
The stick will be length contracted by a factor of 2. It will be observed as only .5m in length.
Meaning when it arrives 10m away and the detectors detect their electrons, they will not light up simultaneously, since the detectors are 1m apart.
Why the difference?
I am certain it has to do with the initial acceleration and relativity of simultaneity, but I'm stumped.
Why the difference?
