Length of the wire that is inside the magnetic field
To find the length of the wire in a magnetic field, the formula F = B . I . L is used, where F is the magnetic force, B is the magnetic field strength, I is the current, and L is the length of the wire. Given a magnetic force of 6.5 N, a magnetic field of 5.3 T, and a current of 5.0 A, the calculation for length results in L = 6.5 / (5.3 * 5) = 0.25 m. Despite this calculation being correct, the homework system indicates it is wrong. This discrepancy suggests a potential issue with the input format or system settings rather than the calculation itself.
lilaznjewel
The magnetic force acting on a wire that is
perpendicular to a 5.3 T uniform magnetic
field is 6.5 N.
If the current in the wire is 5.0 A, what
is the length of the wire that is inside the
magnetic field?
Answer in units of m.
F = B . I . L
L = F / B . I = 6.5 / 5.3 . 5 = 0.25 m
this is what I did, but the homework system says its wrong.
what you did is correct.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
