Let k∈N, Show that there is i∈N s.t (1−(1/k))^i − (1−(2/k))^i ≥ 1/4
In summary: I note this comment at the cited link "analyzing the relevant first derivatives/a well-known limit." Maybe that limit is ##\lim _{x\rightarrow\infty}(1-1/x)^i##.
idobido
not done
Bernoulli's inequality
Newton's Binomial
Taylor expansion
let ##k \in\mathbb{N},## Show that there is ##i\in\mathbb{N} ##s.t ##\ \left(1-\frac{1}{k}\right)^{i}-\left(1-\frac{2}{k}\right)^{i}\geq \frac{1}{4} ##
I tried to use Bernoulli's inequality and related inequality for the left and right expression but i the expression smaller than 1/4 for any i or k.
I also tried Newton's Binomial Theorem, Taylor expansion with no success.
idobido said:
Homework Statement: not done
Relevant Equations: Bernoulli's inequality
Newton's Binomial
Taylor expansion
Since you haven't had any success with the methods you've tried so far, it might be helpful to do some paper and pencil exploration. Start by setting k to 2, and seeing what happens for i = 1, i = 2, and so on.
Then set k = 3, and see what you get for i = 1, i = 2, and so on. You might be able to discover some pattern that will give you insight into a proof.
Maybe plot the function :
##f(x,y):=(1-\frac {1}{x})^y-(1- \frac {2}{x})^y-1/4##?
already did, it seems the f(k, k*ln2) >=0, i.e. k*ln2 is the solution, but this needed to be shown analytically,
and k*ln2 is not a natural number.
Let [itex]f_i(x) = (1 - x)^i - (1 -2x)^i[/itex] with [itex]x \in [0,1][/itex]. This is continuous with [itex]f_i(0) = 0[/itex] for all [itex]i \geq 1[/itex], so the problem comes for large [itex]k[/itex].
And you have continuity + compactness, which guarantee extrema.
ok, only need to show now that
## \alpha\left(k\right)\ :=\ \left(1-\tfrac{1}{k}\right)^{\ln\left(2\right)k}-\left(1-\tfrac{2}{k}\right)^{\ln\left(2\right)k} ##
is decreasing for k>=3, i tried to show the first derivative non-positive but the expression i got is really complicated.
what’s an approximation for ##(1-1/x)^i## for large x?
I note that the original problem statement requires ##i\in\mathbb{N}##, so you cannot set ##i=k\ln(2)##.
The approximation I was thinking of was ##(1-1/x)^i\approx e^{-i/x}##. Using that, it is easy to show that ##i\approx k\ln(2)## near equality of the target inequality. It is not clear from the thread whether you already deduced that or merely observed it numerically.
i observed i = k*ln(2) numerically, i cant use approximation, i need to show that exactly. trying to follow te comments here:
https://math.stackexchange.com/ques...t1-frac1?noredirect=1#comment10074764_4748040
i got stuck at showing that ## \alpha\left(k\right)\ :=\ \left(1-\tfrac{1}{k}\right)^{\ln\left(2\right)k}-\left(1-\tfrac{2}{k}\right)^{\ln\left(2\right)k} ## is decreasing for k>=3
No, I know you can't use that simple approximation to answer the question. My point is that you can use it to show that the appropriate value of ##i## must be close to ##k\ln(2)##.
In principle, you might be able to use a more precise version of the approximation to solve the problem, though.
Note that ##k\ln(2)=k/2+k/12+k/30+…##.
Related to Let k∈N, Show that there is i∈N s.t (1−(1/k))^i − (1−(2/k))^i ≥ 1/4
What is the significance of the condition \( k \in \mathbb{N} \) in the problem?
The condition \( k \in \mathbb{N} \) (where \( \mathbb{N} \) denotes the set of natural numbers) ensures that \( k \) is a positive integer. This is important because the expressions \( (1 - \frac{1}{k}) \) and \( (1 - \frac{2}{k}) \) are defined in terms of \( k \), and the problem involves finding an integer \( i \) that satisfies the inequality. The natural number constraint on \( k \) helps in analyzing the behavior of the expressions as \( k \) changes.
Why is it necessary to find an \( i \in \mathbb{N} \) that satisfies the inequality?
Finding an \( i \in \mathbb{N} \) that satisfies the inequality \( (1 - \frac{1}{k})^i - (1 - \frac{2}{k})^i \geq \frac{1}{4} \) is crucial because it demonstrates that there exists a specific natural number \( i \) for which the difference between the two exponential expressions is at least \( \frac{1}{4} \). This shows that the two expressions diverge sufficiently as \( i \) increases, which is a key part of the mathematical proof or argument being made.
How can one approach proving the inequality \( (1 - \frac{1}{k})^i - (1 - \frac{2}{k})^i \geq \frac{1}{4} \)?
One approach to proving the inequality is to analyze the behavior of the expressions \( (1 - \frac{1}{k})^i \) and \( (1 - \frac{2}{k})^i \) as \( i \) increases. Since \( 1 - \frac{1}{k} \) and \( 1 - \frac{2}{k} \) are both positive numbers less than 1, their powers will decrease as \( i \) increases. By comparing the rates at which these expressions decrease, one can determine a suitable \( i \) that makes the difference between them at least \( \frac{1}{4} \). This often involves using properties of exponential decay and inequalities.
Are there any specific values of \( k \) for which the inequality is easier to prove?
For larger values of \( k \), the expressions \( 1 - \frac{1}{k} \) and \( 1 - \frac{2}{k} \) become closer to 1, which makes their powers decrease more slowly. However, the
