Levi-Civita Symbol multiplied by itself
  • Thread starter Thread starter RolloJarvis
    Levi-civita Symbol
RolloJarvis
evaluate \epsilon_{ijk}\epsilon_{ijk} where \epsilon is is the antisymetric levi-civita symbol in 3D
determinant of deltas = product of levi-civita -> would take ages to write out.
\epsilon_{ijk}\epsilon_{ijk}=\delta_{kk}\delta_{ll}-\delta_{lk}\delta_{kl}=1-2\delta_{lk}
But i have a feeling the answer is 3? (because of this)
Well, firstly clean your notation. It should be
<br /> \epsilon_{ijk}\epsilon_{ijk}=\delta_{kk}\delta_{jj}-\delta_{jk}\delta_{jk}<br />
And there is a summation over j and k.
So that gives
<br /> \sum\limits_{j,k}\delta_{kk}\delta_{jj}-\delta_{jk}\delta_{jk} = 3.3-3 = 6 = 3!<br />
Also 3! = 6, not 3.
Thanks a lot. I was in a rush and I am pretty stressed at the moment as its only a few days before exams, the \epsilon [\tex]was supposed to read \epsilon_{jlk}[\tex].&lt;br /&gt; &lt;br /&gt; How is it okay to swap the order of indicies on the delta funtion as you have done: i.e. \delta_{ij} = \delta_{ji}[\tex]
ya, that's a property of the delta function.
again, thanks a lot
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
11K
