Levitating Metal with a Solar Cooker: A Feasibility Study
In summary, a solar cooker can be used to levitate a piece of metal using a focused beam of sunlight. The foil will do every possible trick to move to sides and rotate - leaving the beam.
dansmith170
45
TL;DR Summary
I would like to build a solar cooker that can levitate a thin piece of metal using sunlight, will it work?
I would like to build what is usually used for heat production and is called a solar cooker. However, I would like to use it to try to levitate a piece of metal.
Here are my assumptions:
A. aluminum density = 2.7 g / cm^3
B. Sunlight intensity on Earth's surface is about 1000 W / m^2
C. aluminum thickness = 2.5 micrometers (https://geistnote.com/2-5-m-aluminum-foil/)
D. Aluminum area = 1 centimeter squared
E. solar cooker area = about 2 square meters
F. acceleration due to gravity on Earth = about 9.9 meters / second^2
G. I take it that some kind of lens maybe be necessary to focus the light reflected off the solar cooker to a smaller area of about 1 square centimeter.
If my math is correct, I think the force of gravity on aluminum with the aforementioned specifications equals about 6.6 microNewtons. The force of sunlight focused from the solar cooker to an area of 1 square centimeter equals about 12 microNewtons. So, the resultant net force on the piece of aluminum foil should be about 6 microNewtons and should be directed skywards. This should cause the aluminum foil to levitate or move in the skyward direction, counter to the direction that gravity would otherwise cause it to move.
Does this sound like it could work? I guess one concern I have is whether this much focused light would melt the aluminum foil.
You must carry out the experiment in a vacuum, or the aluminium would instantly burn in the oxygen of the atmosphere, then rise as a thermal plume.
If you use a lens, the lens will get hot because it is not perfectly transparent at all wavelengths. Use mirrors that radiate heat from their back surface.
The Sun has a diameter of just over 0.5 degrees when viewed from the Earth. You will need some fancy optics to concentrate that area of energy to a point, then collimate it to be a parallel beam, pushing in one direction.
Likes russ_watters, BillTre and berkeman
Likes russ_watters and Tom.G
FAQ: Levitating Metal with a Solar Cooker: A Feasibility Study
What is the basic principle behind levitating metal using a solar cooker?
The basic principle involves using concentrated solar energy to heat a material to a point where it can generate a magnetic field strong enough to counteract gravity, allowing the metal to levitate. This typically involves the use of superconductors or strong magnetic fields generated by induction heating.
Is it possible to achieve the necessary temperatures with a solar cooker?
Yes, it is possible to achieve the necessary temperatures with a solar cooker, especially if it is designed to focus sunlight to a very small area. Advanced solar cookers can reach temperatures above 1000°C, which is sufficient for some metals to become magnetic or for creating conditions conducive to levitation.
What kind of metals can be levitated using this method?
Metals that can be levitated using this method are typically those that have magnetic properties or can become superconductors at high temperatures. Examples include certain alloys and compounds that exhibit strong magnetic responses when heated.
What are the potential applications of levitating metal with a solar cooker?
Potential applications include materials science research, where controlled levitation can allow for the study of metal properties without container contamination. It could also be used in advanced manufacturing processes, magnetic levitation transport systems, and novel energy storage solutions.
What are the main challenges in levitating metal with a solar cooker?
The main challenges include achieving and maintaining the extremely high temperatures required, ensuring the stability of the levitated metal, and managing the precise control of the magnetic fields involved. Additionally, the setup must be able to handle the intense energy focus without degrading or becoming damaged.
