Lifetimes of jet aircrafts and their engines
  • Thread starter Thread starter Astronuc
    Engines Jet
The lifespan of jet aircraft varies significantly based on their type, with narrowbody planes like the Airbus A320 lasting nearly 50,000 flight cycles, while long-range models like the Boeing 747 have an estimated lifespan of 35,000 cycles. Jet engines typically require replacement or overhaul multiple times during the aircraft's life, with narrowbody engines needing attention after 12,000 flight cycles, followed by further overhauls at reduced intervals. Airlines often opt for engine replacement over costly rebuilds due to the mechanical and thermal stresses experienced during operation. Smaller business jet engines, such as the JT-15D-5, have shorter overhaul intervals, averaging around 1,800 flight hours. Engine swaps can be completed efficiently, often within 2-3 days, highlighting the operational considerations in aircraft maintenance.
Astronuc
Staff Emeritus
I found this article today.
Jalopnik - Here's How Often Airlines Replace the Jet Engines on Passenger Planes
The rated lifespan of a plane can vary widely by fuselage size and composition. Short-range narrowbody aircraft, like the Airbus A320, can last almost 50,000 flight cycles. According to Simple Flying, long-range widebody planes have a life that can range between 25,000 and 45,000 cycles. For example, the iconic Boeing 747 has a manufacturer-estimated lifespan of 35,000 flight cycles. The composite-structured Boeing 787 Dreamliner can endure 44,000 flight cycles, 9,000 more than the jumbo jet.
https://jalopnik.com/how-airlines-decide-to-replace-jet-engine-boeing-airbus-1850275010
The plane’s jet engines will not last the aircraft’s entire lifespan and will have to be replaced at some point. Engines are overhauled two or three times before being taken out of service. For narrowbody engines, this usually happens after 12,000 flight cycles. The number of cycles is cut down to 8,000 until the second overhaul and then halved to 4,000 for the third. However, airlines may simply replace the engines instead of spending millions on further rebuilds.
Likes mfb, Klystron, berkeman and 2 others
It makes sense if you think about it, though. You have a lot of transient loads, both mechanical and thermal, during startup and shutdown alone, let alone the takeoff. Once you get steady state at cruise, they're not nearly as heavily stressed and can run for long stretches of time, which is why most airliner engines are monitored by cycles as well as run time. Accessories on the gearbox can be time limited instead of cycle limited, but even then, most of it is "on condition".
That said, I am somewhat familiar with the smaller engines used on business jets and those both have shorter intervals between overhauls and can undergo more overhauls, iirc. The JT-15D-5s that I worked with were ~1800 flight hours between "hot section" (combustion and power turbine sections) overhauls, which came to about 2 years or so for the planes I worked with. Total overhauls were every other hot section. I don't know what the life limit on the engine was, but it was quite a while, probably comparable to the life limit of the airframe at 36k cycles for the Hawker 400s I worked with.
That said, engine swaps are actually pretty quick once you do a couple of them. We got it down to ~2-3 days for a dual engine swap on the 400s, and that was doing one at a time because we only had one hoist to install/remove engines. Single swaps were basically unheard of outside of a FOD incident.
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
37K
