Light Beams Attraction: e=mc^2 & Asymmetry
In summary: So the more powerful beam can deflect the weaker beam by a distance r if the power ratio is greater than 1.
c704710
Appearently, two beams of light in a vacuum are attracted to each other. Photons have no Newtonian mass, but their relativistic mass (e=mc^2 or mass-energy equivalence) causes this (as is my understanding). So will a 10^4 Hz beam bend more towards a 10^20 Hz beam than the 10^20 Hz bends towards the 10^4 Hz beam? After all, e=mc^2 indicates the 10^20 Hz beam has more relativistic mass doesn't it? However, if they equally bend, why?
You are applying special relativity concepts to GR. In GR, the problem you pose is not simple. For example, are you aware that two beams of light traveling in the same direction do not attract, while if traveling in opposite directions they do? Note that relativistic mass is a dubious construct in SR, and has no relevance whatsoever for gravity (GR).
Published research I've seen using GR uses identical beams. However, one thing to note is that there is always a frame of reference where the beams have equal energy density. One may then state that deflection is equal such coordinates.
Likes Pyter
Only if they are not moving parallel to each other. See below.
The source of gravity in GR is the stress-energy tensor. This includes energy (what you are calling "relativistic mass", but it's better to just call it energy), but also pressure (and other stresses, but pressure is the relevant one here).
It turns out that, for light beams moving parallel to each other, the effects of energy and pressure exactly cancel, so the beams don't attract each other at all. For light beams moving antiparallel, the effects of energy and pressure add, and the actual attraction between them turns out to be four times what you would expect based on the energy alone.
The attraction (for beams not parallel to each other--see above) is proportional to the product of the beam energies (and pressures, see above), so it's not really a question of which one "bends more".
Likes Pyter and stoomart
Thank you for the information concerning the parallelism of the beams. I was unaware of that and the 4 times effect as well. So I _think_ my question was answered. The result is a shared effect of the beams rather the each beam effecting the other? Therefore symmetrical regardless of asymmetric frequencies?
This means a 14 TeV laser beam can be diverted with a pocket laser!?
What does "symmetrical" mean? I think you will find that you are implicitly adopting a particular coordinate system.
Note that in a frame moving near c in the direction of powerful laser, the two beams have equal energy due to Doppler. The description of deflection in these coordinates is symmetric. Then, a Lorentz transform gets you the description in any other frame.
Specifically, if the power ratio in one frame is r > 1, then the fraction of lightspeed needed to equalize the power is (r-1)/(r+1) in the direction of the more powerful beam.
Likes PeterDonis
Related to Light Beams Attraction: e=mc^2 & Asymmetry
What is the meaning of "e=mc^2" in relation to light beams attraction?
The equation "e=mc^2" is known as the mass-energy equivalence equation and was proposed by Albert Einstein in his theory of relativity. It states that energy (e) and mass (m) are equivalent and can be converted into each other through the speed of light (c) squared. In the context of light beams attraction, it means that the energy of light and its mass are directly related and can influence each other.
How does asymmetry play a role in light beams attraction?
Asymmetry refers to a lack of symmetry or balance in a system. In the case of light beams attraction, asymmetry can occur when the light beams have different energies or when they are not aligned in a symmetrical manner. This can lead to an imbalanced attraction between the beams, causing them to either repel or attract each other.
Can light beams attraction be explained by other scientific principles?
Yes, there are other scientific principles that can help explain light beams attraction, such as the laws of electromagnetism and quantum mechanics. These principles describe how particles and fields interact with each other, which can also play a role in the attraction of light beams.
What are some real-world applications of understanding light beams attraction?
Understanding light beams attraction can have practical applications in various fields, such as optics, astronomy, and particle physics. It can also help in the development of new technologies, such as laser technology and particle accelerators.
Is there ongoing research or experimentation related to light beams attraction?
Yes, there is ongoing research and experimentation related to light beams attraction. Scientists are constantly studying the behavior of light beams and how they interact with each other, as well as developing new theories and technologies to better understand this phenomenon.
