LightningInAJar
- 213
- 30
I heard somewhere that light in the visible spectrum that we see interacts with matter the most? Is that true, and in what ways?
LightningInAJar said:I heard somewhere
Interacts how? A lot of matter interacts with light. Ok, so...what?LightningInAJar said:I heard somewhere that light in the visible spectrum that we see interacts with matter the most? Is that true, and in what ways?
That is rude and a bachelor's.russ_watters said:Interacts how? A lot of matter interacts with light. Ok, so...what?
This is not intended to be rude, but; what level of schooling have you completed and what research have you done on your own? This question seems both odd and basic.
LightningInAJar said:I was reading something somewhere (don't remember where or else I could read more into it) that the reason we see within the spectrum that we do is because that "light" interacts more with matter than than radiation outside of it. I know dark matter doesn't interact with light and that is most of the universe. At least not wavelengths we can currently measure anyway. Maybe our light spectrum interacts largely with matter below a certain atomic weight?
Not really : he's trying to find out what you mean by your question, specifically "interact".LightningInAJar said:That is rude and a bachelor's.
It's not rude. He's trying to figure out how to best answer a confusing question.LightningInAJar said:That is rude and a bachelor's.
"Interacts better" is a subjective judgement that depends on the goal of the unspecified interaction. In many cases, the answer would be "no". E.g.:LightningInAJar said:http://news.mit.edu/2016/all-photons-imaging-algorithm-0929
At least in terms of body materials our body interacts better in the visible spectrum?
I'm just being difficult here but many molecules absorb and emit radiation with mm and cm wavelengths - in a very measurable way. Thing is, when you have a very tight resonance, that general wavelength / size rule falls down. We have all had a cheap radio receiver with a ferrite rod, for receiving mf and lf signals. The rod (the whole receiver even) may be only say 10cm long but it picks up 1500m wavelength signals with no trouble. How? the very tight resonance that the rod material gives the matching (aka tuning) circuit plus the fact that it looks at the magnetic field rather than mainly the electric field.Ibix said:It's worth noting, though, that waves typically don't interact with things much smaller than their wavelength.
The wavelength of light determines the amount of energy it carries. This energy can determine how the light interacts with matter. For example, shorter wavelengths (such as gamma rays) can cause ionization and damage to cells, while longer wavelengths (such as radio waves) are less energetic and can pass through matter without causing much interaction.
Yes, different wavelengths of light can be absorbed differently by the same type of matter. This is due to the unique energy levels and properties of each type of matter. For example, plants absorb red and blue light more efficiently for photosynthesis, while green light is reflected, giving leaves their green color.
Transparent materials allow light to pass through without any significant absorption or scattering. Translucent materials allow some light to pass through, but also scatter and diffuse the light. Opaque materials absorb or reflect all incoming light, making them appear dark.
Yes, the wavelength of light can affect the color of an object. Objects appear a certain color because they absorb all other wavelengths of light and reflect the color that we see. For example, a red object appears red because it absorbs all other colors of light and reflects red light.
The interaction of light with matter is essential for the formation of rainbows. When sunlight passes through water droplets in the atmosphere, it is refracted and dispersed into its component colors. This is due to the different wavelengths of light being bent at different angles, creating the beautiful spectrum of colors we see in a rainbow.
