Light shone in a train bouncing off mirrors
In summary, the conversation discusses a thought experiment involving a train and mirrors with a beam of light. The person on the train sees the light go straight up, but an observer outside sees it travel diagonally. The question is raised about the constant speed of light and why both observers don't see the light hit the mirrors slightly behind where it bounced. The experts explain that the laws of physics are the same regardless of constant velocity, so the beam of light must also travel parallel to the train in both frames.
  • #141
jefswat said:
That is why I included the disclaimer. Because that notion is prone to lead people off track.exactly, Fundamental would be, red light has wave length 600nm. the light is 600 nm. you think its blue I think its red. Non-Fundamental would be along the lines of disagreement on the wavelength and so on. It doesn't make sense because one of the observers made a clear error.
I believe I cleared that up?
I have to go to class I will finish later. Do you now agree with my definitions?
No, nothing you said makes sense. Nobody made an error. The color-blind person points and says "light gray". He's not in error unless he then states that "light gray" is not the color of a stop light. The normal person thinks the color-blind person is in error because s/he assumes the color-blind person means the exact same thing s/he does by "light gray". The normal person, instead of assuming this, asks the color blind person what s/he means by "light gray". The color blind person says "Light gray is the color of love, blood, bricks, stop signs, stop lights, and freckles. The normal person agrees that the stop light is indeed of a color similar to all those things, which s/he just happens to call "red" instead of "light gray".
Doc Al said:
It's not "logic" telling you things, it's your questionable notions about the way things work. You claim that a statement such as "X is longer than Y" is some kind of "qualitative" statement and thus frame independent. Yet it involves measurements of length, which are intimately tied to our notions of simultaneity and time and which we know are frame dependent.
Qualitative statements are an either or situation. They may be based upon a measurement, but ultimately the output is a 1 or a 0. Measurements may be quantitatively different in different frames but they cannot output conflicting qualitative conclusions. In general I've shown that SR is fine on this matter, i.e. different frames reach the non-contradictory conclusions in all instances. Except for this "relativity of simultaneity" issue. This is the only situation where there is qualitative disagreement. The fact that it's the ONLY one within the theory that violates this rule and my own logical assessment tell me there is something wrong here.
Doc Al said:
It's perfectly reasonable (inescapable, really), given what we mean when we say that X or Y has a length, for two different observers to disagree on which of two objects is longer. (Of course, observers who are aware of how the world actually works are not at all surprised by this.)
You cannot illustrate a single instance where two observers will reach different qualitative conclusions unless they are A) Sloppy or B) Talking about non local simultaneity
Doc Al said:
Again, there is no contradiction. The fact that measurements of length and time, and thus comparisons of distances and intervals, are frame dependent presents no contradiction. You have yet to give one single instance (other than handing waving philosophy) where there is a real contradiction.
Sounds to me like you are more interested in discussing your preconceived "metaphysical" notions than in discussing physics.
I'm concerned that, in general, the "no qualitative contradictions" rule holds up within SR except in a specific case, the "relativity of simultaneity".
  • #142
altonhare said:
But of course velocity is a vector. If O2 is at rest relative to B, then the velocity of A is now negative.
Speed is not a vector though. You claim that if different frames disagree on which of two objects has a larger value of X, this would be a logical contradiction; does this not apply when X=speed even though you think it applies when X=velocity?
Also, of course if O2 just rotates his coordinate system 180 degrees so that the new direction of increasing x-coordinate was the old direction of decreasing x-coordinate, then in this new coordinate system A will have a positive velocity while B is at rest.
JesseM said:
No, of course there aren't. But there's also no reason to believe there is any ontological truth about "velocity", since velocity is an inherently coordinate-dependent concept. Do you believe there's an ontological truth about which of two objects has a greater x-coordinate, or do you agree that an x-coordinate is an inherently coordinate-dependent concept?
altonhare said:
There are no ontological contradictions and this scenario is no different, as I pointed out.
Wait, when you say it's "no different" that means you believe there is an ontological truth about which of two event "really" has a greater x-coordinate, independent of our choice of coordinate system? This would seem to imply you believe the universe contains a ghostly "true" x-axis, such that if one event has a greater x-coordinate on the One True x-axis, then it "really" has a greater x-coordinate in an ontological sense, even though an observer could perfectly well choose a coordinate system with a different origin or rotated coordinate axes where the same event has a smaller x-coordinate.
altonhare said:
Logic tells me that observers should not come to qualitatively different conclusions and that, if they do, they have made at least one mistake.
How does "logic" tell you that? Different coordinate systems are just different ways of labeling events, much like different languages are different ways of naming objects. Do you think it is an ontological truth that the animal we call "giraffe" has a longer name than the animal we call "cat", even though in a different language the first animal might have a shorter name? Or do you agree that there need be no ontological truth about which of two animals has a longer name in a language-independent sense, that the very notion of "name length" is inherently relative to a particular choice of language? If the latter, I don't see how there could possibly be anything inherently illogical about the notion that "velocity" or "x-coordinate" are inherently relative to a particular choice of coordinate system (which, again, is just a convention for labeling events), and that there would be no ontological truth about which object has a greater "velocity" in a coordinate-independent sense.
altonhare said:
Reason tells me that we cannot hang our concerns on each one's "frame" because this is an artificial construct, a matter of perspective.
Yes, and my argument is that certain quantities are inherently frame-dependent, and thus there is no objective frame-independent reality about which of two objects has a greater velocity, the answer will depend on which of these artificial constructs we happen to use. Similarly, language is an artificial construct for assigning symbols to objects and concepts, and there is no objective language-independent reality about which of two animals has a longer name.
altonhare said:
Perspective shouldn't change what is.
Why do you think velocity (or x-coordinate) is part of "what is"? Do you think "name length" is part of what is?
JesseM said:
If you just assume that there must be an objective truth about whether events are "really" simultaneous (despite the fact that different SR coordinate systems disagree about whether they share the same t-coordinate) whereas you don't think there must be an objective truth about whether events "really" share the same x-coordinate in some sense that's independent of human choices about how to define coordinate systems (i.e. you don't assume there's some ghostly 'true' x-axis in the universe and that any coordinate system whose x-axis is rotated relative to the 'true' one is incorrect in some objective sense), then you are just begging the question here, assuming what you are trying to prove.
altonhare said:
Hmmm. I don't think there is a "ghostly x axis" that is "out there". I think that observers in "rotated" coordinate systems, if they report their measurements specifically and clearly, will not contradict each other.
They won't get physical contradictions as long as they understand that coordinate-dependent quantities don't represent objective physical truths. But do you deny that for two points in space, two different coordinate systems can disagree about whether they share the same x-coordinate or not? For example, in one system point A might be assigned coordinates x=0,y=0 while point B might be assigned x=4,y=3, but then in a second coordinate system with axes rotated relative to the first, point A might be assigned coordinates x=0,y=0 while point B is assigned x=0,y=5. Notice that this has nothing to do with relativity, it's just about coordinate systems whose axes are oriented differently in ordinary 2D geometry. So: do you think there is an objective, coordinate-independent truth about whether point A and point B share the same x-coordinate? If so, how can you justify this without believing in a ghostly "true" x-axis which is independent of the choices we fallible humans make about how to orient our own coordinate axes?
altonhare said:
For instance, O1 is observing X. S/he first gets a handle on its relative location. How does s/he do so without leaving O1's frame?
The standard procedure in SR is for O1 to define everything in terms of local measurements on a system of rulers at rest relative to O1, with clocks at each ruler-marking that are synchronized according to the Einstein synchronization procedure. Than if X passes next to the 3-meter mark on his x-axis ruler when the clock at that mark reads 5 seconds, O1 will say that in his frame, X was at position x=3 meters at time t=5 seconds. And if X is an extended object, O1 is supposed to define the length of X by looking at where the front and back of it was at a single time according to his clock system. For example, if the front of X was at the 10-meter mark when the clock there read 2 seconds, and the back of X was at the 15-meter mark when the clock there read 2 seconds, then X must have a length of 15 - 10 = 5 meters in O1's frame.
altonhare said:
If other observers, in other states of relative motion, perform the same procedure they will arrive at consistent conclusions without a "coordinate transform". O1 says that X was 3 "meters" in extent in the direction in which it was 10 "meters" from Y while Y is 4 meters in extent in this direction. X was 5 meters in extent in the direction in which it was 8 meters from Z and Z was 2 meters in extent. The qualitative conclusion is "X is greater in extent than Z in the direction of Z, i.e. on a line connecting X and Z and X is smaller in extent than Y in the direction of a line connecting them". O2 says that X was only 1.5 meters in extent in the direction in which it was 3 meters from Y while Y was 2 meters. X was 8 meters in extent in the direction it was 12 meters from Z, while Z was 7 meters. O3 states... etc. These statements are not contradictory, they are simply different. In these sense there is no "absolute truth" behind length, width, and height. But also observers in different "coordinate systems" do not arrive at contradictory results if they are specific about their results. If O1 simply says "X is longer than Z and shorter than Y" while O2 says "X is shorter than Y while longer than Z" then they are simply being sloppy.
If each observer uses the procedure I discuss above, then there can in fact be situations where different frames disagree about which of two objects is longer, even if they agree on the orientations of their x-axis, y-axis, and z-axis.
And again, do you think your claim about observers never disagreeing about which of two objects has a greater length should also apply to questions of which of two events has a greater x-coordinate? In this case, as I said we don't even need to think about relativity to see that different coordinate systems can easily disagree on this.
altonhare said:
Absolutely not. The entity would be moving wrt every other non-aether entity. The aether is just another arbitrary frame, albeit it may be the most convenient one.
But I'm not using "Lorentz ether theory" to refer to the notion of an actual physical ether, but just to the notion that there is some absolute truth about frame-dependent ideas like simultaneity and length and velocity, there needn't be any physical substance at rest in the preferred frame.
altonhare said:
I see no evidence, empirical or logical, to support the block universe ontology.
Where have I said there was? I just said there is nothing logically contradictory about it.
altonhare said:
You cannot cut a 3D block into 2D planes. Whatever slice you cut off will necessarily be 3D. 2D planes are abstract objects, i.e. we can visualize them but they lack location (do not exist).
Yes, the "slicing" is purely abstract, not physical. If you define an x-y-z coordinate system in 3D space to label every point, then if you take the complete set of all points that have some fixed z coordinate, this set forms an abstract 2D plane. Similarly, in the block universe I didn't mean to suggest a magical knife that could actually cut through 4D spacetime, I just meant that you could define different coordinate systems in this spacetime, and a complete set of events with some fixed t coordinate forms an abstract 3D moment.
altonhare said:
One person I debated a similar topic with ended up just asking if I could "consider that which I cannot imagine" or "that which is outside my realm" or "that which is simply inconceivable". Of course I cannot consider that which I cannot imagine, I cannot imagine it. I must imagine to consider.
Any mathematical description of something is a way of imagining it, even if we can't form a visual picture of it. I can't visualize colors of light outside the visible spectrum but I can form a mathematical model of such light in terms of its frequency, and use the model to make predictions about experimental results involving infrared or ultraviolet radiation.
  • #143
So?
Sure they can.
Uh... You do realize that this "relativity of simultaneity" issue is at the heart of relativity?
Also, your use of the term "non-contradictory" is non-standard. You have yet to show how SR leads to any actual contradictions. All you've shown is that it contradicts your arbitrary "rule". So what?
I'd say that the problem is your insistence that "qualitative" statements must be frame independent.
That might well be true. So?
If you want to understand relativity, you'd better get used to the relativity of simultaneity (as well as length contraction and time dilation).
  • #144
I don't understand why you won't take what I say without putting your own spin on it.
Non-Fundamental disagreement The quote would be a definition of Non-Fundamental disagreement. Clearly they are just disagreeing about something superficial. I say a car has length(the traditional sense) of 6 and you say it has length 2. there is a contradiction here because one says 2 and one says 6. However if I then told you one thought 6 feet, the other thought 2 yards you would agree there is no contradiction because they simply did not agree on something superfical like the scale they were using. In general non-fundamental disagreement is about the details like definitions or how fast you were going. I am going south at 10 m/s on a given cordinate system. a ball is stuck at the origin. You are going 15 m/s north. obviously we both conclude that the ball is moving at a different velocity relative to ourselves. Then the uneducated one assumes that one must be wrong. but when you look at the details you see that both answers are in fact correct because of the word relative.
Fundamental disagreement is far more severe. All parties involved agree on everything except the final outcome. I define red to be 600nm wavelength(I made that up). We measure light of 600 nm. I think its red, you think its blue but we both agree that 600nm wavelength is red light. obviously the person who thinks its blue is just not thinking clearly. This is the kind of disagreement that leads to fatal flaws in theories and contradictions that can't be solved. It is also the type of disagreement that after 100 years, SR still have not been proven to have.
Does anyone else have a problem understanding this? Its basic philosophy.(Thats actually where I stole it from)
Really? A is going faster than B. A is going MUCH faster than B. A is barely going faster than B. I make no mention of numbers.
In my ball example, I measure the ball to be going north at 10 m/s. You measure the ball to be going south at 15 m/s. If you still don't feel that north and south are qualitative, replace them with up and down. One observer says up at 10 m/s, the other says down at 15 m/s. they both disagree on qualitative and quantitative measurements. You need to use relativity to reconcile these to disagreements Furthermore, if a wall is also moving towards the ball at 10 m/s, but is on the other side of it from me, I see the ball hit the wall. the other observer sees the wall hit the ball.
I think you need to start new and give us your theory as it stands now. You have changed your mind so many times that I don't know what you believe anymore and consequently, my arguments may be outdated and therefore irrelivent.
  • #145
Fundamental disagreement is far more severe. All parties involved agree on everything except the final outcome. I define red to be 600nm wavelength(I made that up). We measure light of 600 nm. I think its red, you think its blue but we both agree that 600nm wavelength is red light. obviously the person who thinks its blue is just not thinking clearly. This is the kind of disagreement that leads to fatal flaws in theories and contradictions that can't be solved. It is also the type of disagreement that after 100 years, SR still have not been proven to have. Does anyone else have a problem understanding this? Its basic philosophy.(Thats actually where I stole it from)
I agree. I usually put it this way: you cannot mistake Cinderella by the slipper, which is just a crafty way to catch her, a clever invention of the human mind for hunting purposes, but not the target itself.
Everything Althnonhare says makes sense if you substititute “measurement” (the slipper) for “quantitative” and “reality” (Cinderella) for “qualitative”.
What else can be the final outcome, other than what you seek from the beginning = solve practical problems where real things that “exist” are involved and interact with others, producing events that “happen” and causing us practical concerns (did Althon murder Mathe?, was the duel fair?).
I do not see why Althonhare insists on labelling as the outcome or the target of the exercises, on putting at the privileged place of things that are unique and fundamental, a mere concept like simultaneity. Simultaneity, like time, does not exist, it is not real. It is a concept, a mere human invention that, in itself, is neither absolute nor relative: it is, like all other concepts (like the slipper), either functional or non-functional, it serves its purpose or not. If thanks to the trick, you catch and marry the real Cinderella, it was good; if instead, because one of the step sisters has trimmed off her heel and manages to put on the slipper, you marry her, it is clear that the trick didn´t work, probably because you had lost the north of the exercise and had started to reify the slipper and think that the instrument, a certain configuration of the trick, was the game itself.
The concept of relative simultaneity of SR cannot be accused of this mistake, because it has been framed so as to respect reality: all observers who apply it (by combination with other measurement of other relative concepts) agree that the same “events” happen, which leads to a single outcome, a single solution to the issue at stake: the real murderer is sent to jail and the bad referee is sanctioned. Here the simile is legal but you can replace it with any other practical problem you encounter in real life (if this life is real, but apparently it seems so!).
Therefore, the “different judgments of simultaneity” are valid and true, as long as each of them works and enables us to identify the real murderer or the referee who rightly declared the duel fair or unfair. But we must not forget in which sense they are both valid and true: only because they did the trick, they wouldn’t if they didn’t!
Forgetting this may lead us to two kinds of mistakes.
1) Althonhare’s mistake: identifying as preferable in absolute terms just one version of simultaneity, just because it happens in the same frame where the rest of the instruments are placed. Preferring the reading of the clocks of the train, just because the hot chair is on it or the duel takes place on the train. That is conceptually wrong. That equates to saying that what is relative, what has been designed as a relative concept precisely because it thus serves its purpose, is absolute, just because it is absolute. And what does that mean? Nothing? The judgment of the train is only an instrumental concept, and as such it will be valid and useful if it works and invalid if it doesn’t work, just like the judgment on the ground.
But there is a caveat! I can concede that he is somehow (not conceptually but instrumentally) right if we introduce the element of test and trial. In his configuration, he mentions that electrical engineers have tested the device numerous times and checked that it works. Certainly, even in that case, the observer on the ground may obtain the same prediction of the outcome and if this is so, both are right and saying that the electrical bolts (or the instants when the dueller see the signal for shooting) are simultaneous or not is just an accessory matter, where both parties are entitled to be right. (Accessory, Jesse, only in the sense that it is a piece to reconstruct the puzzle of reality, not the puzzle itself, but of course it is an essential part of the puzzle). However, if it is proved that the system works on the train, on the basis of its judgment of simultaneity, and that it wouldn’t work on the basis of the judgment of simultaneity of the ground, then it is clear that there is something wrong…
Where? Well, in that case, I would not still dismiss SR. The idea, the trick, is still valid. We would just have to check how we have adapted the idea to reality. And this has a lot to do with the way we have designed our physical measurement instruments and the way we have drafted our formulas, in order to better account for how things work. Because that, and not other, is the way things are: the universe does not conform to relativity, relativity must conform to the universe if it aspires to catch reality and solve problems successfully! You shape the slipper following the mould of Cinderella’s foot, not the other way round.
2) Thus we introduce the second mistake. You often hear the contention that time and simultaneity are relative because… that is the way the universe is! Other times you hear that SR, as a scientific theory, does not enter into the philosophical discussion of what time is, but it can be affirmed that time is always and will always be measured as relative.
That is also conceptually wrong. Time is neither absolute nor relative, because it does not exist. Time, I agree, is what is measured as such. The rest of the concept that is usually intermixed with measured time in common language is the idea that things happen, “reality”. But I agree that in science reality must be kept as the north (if only we could plug it into the equations!) and then we must work and do mathematics with measured time, that is to say, the periodic motion of “objects” (whether mechanical or electromagnetic) within some portion of space that encapsulates it.
But is there any physical reason why forcefully you always have to hit on a relative measurement, different for each frame with a different state of motion? You can never know. Sometimes there may exist funny compensations of effects that lead to homogenous results, which are identical for different observers. If there is no dogmatic barrier, we cannot discard that this might eventually happen, unless of course there is a sound physical reason forbidding it.
That was the argument of classical relativity. If you take out from it Newton’s never clear assertion that there is an absolute time (did he refer to a real entity, which would be wrong, or to a mere intellectual concept, which would be legitimate, as a tool for discussion?), you find that it is the same model as SR, except for the belief that mechanical clocks give homogeneous measurements, no matter the state of motion of the holders. That is to say, when you say that two events happen simultaneously as measured by synchronized mechanical clocks, you can be certain that it is logically impossible that, right after their conclusion, one is and the other one is not yet real. Thus, no matter if you traveled from one to the other 1,000 times FLT, you could not prevent the second from happening. In other words, the idea is what has been discussed here: reality is one, it is the one fundamental thing, and you predict its behaviour by measurements, it is only that in classical relativity you combine for this purpose a relative space with purportedly homogeneous length and time measurements, while SR points out that your instruments, in practice, will also render relative results in terms of length and time, so you have to follow a more complicated route, a few more turnings, in order to reach the same target.
However, what are the practical reasons? All examples I’ve seen are based on light instruments, light clocks and light rods. I am clearly shown that, if you measure time and length with light and postulate that the speed of light is constant, you get the Lorentz Transformation, with which you catch reality and marry Cinderella. But which Cinderella? For sure, a light Cinderella. But also a mechanical one?
Well, at this stage, I am told that, if it were not so, the principle of relativity would not be respected and the universe would not fully conform to it. But for me the principle of relativity is just an intellectual trick, a slipper. The universe has no obligation to conform to it. It is valid if it is practical, if it catches reality and solves practical problems. And if it didn’t, under certain circumstances, and to the extent it didn’t, what should we do? We should still not dismiss it, but we should adapt either our measurement instruments or our laws of physics so that it works again. Again: if the slipper is not a valid mould any more, you simply have to reshape it.
Maybe that is what has been done and I have not realized it. But if it is so, please, experts on SR, tell me how it has been done: how have you shaped your instruments and formulas so that, even if they are made on light, they catch mechanical Cinderellas?
That is a sort of discussion that would be exciting. Let us forget aprioristic constraints about the principle of relativity and explain how we have shaped it (because we have shaped it, no doubt, that is what SR means versus Galilean relativity) so that it matches both light and mechanical Cinderellas, to the maximum degree of certainty.
Of course I do not expect to prove that anything is wrong with mainstream science. I am neither stupid nor a crankpot. I just think that this conceptual framework is right and hence it is more pedagogical, it serves to better explain the theory, most probably not to change it. The idea is: start talking about the physical configuration of your instruments and how they interact with the environment, note the differences between light and mechanical objects (which do exist, otherwise why SR?) and then explain to me how, in spite of those differences, SR has been carefully shaped in order to catch all aspects of reality.
For this purpose, I thought that both Althonhare’s and the duel example were a good stage. The question is very simple. Take for example the show of the duel. The signals for the duellers to shoot have been given through light, which does not take the motion of the source. If the duellers shoot with laser guns, it is clear that the match is fair. But if they received light signals and shot normal bullets with conventional arms, which do take the state of motion of the source, would it be still fair? It is clear that, if the ground observer uses the relativistic formula for the addition of velocities, he predicts that the duel is fair. But those are calculations. That doesn’t mean that this is what is going to happen on the train. What am I missing here? Can you please be pedagogical and explain this to me? Sincerely I have no hidden intention and just want to learn. If you want to continue your discussion and prefer not to take this question, am I then allowed to start a new thread without being labelled as a crankpot…? Thanks for your comments.
  • #146
That's the whole point of special relativity. Maxwell's equations are of light. They did not obey the predictions of Galilean relativity between frames with constant relative velocity. The Michelson-Morley experiments showed that Maxwell's equations were the same in in frames with constant relative velocity, thus showing that the nature obeys Lorentzian relativity between frames with constant relative velocity. So the Michelson-Morley experiment caught a light Cinderella!
But it also caught a mechanical Cinderella! The Michelson-Morley apparatus was not made of light, but of the materials of mechanics, and mechanics was used to build it. It showed that we cannot have the laws of light obeying Lorentzian relativity, while having laws of mechanics obeying Galilean relativity.
So special relativity was invented to make all the laws of physics, not just of those light, consistent with Lorentzian relativity.
  • #147
Thanks, atyy. I would like to be very specific and focus on a concrete example, like Alhon's or the show of the duel. In the duel the problem is: Two light signals sent from the mid-point of the car reach the duellers, at the trail and the tip. If the duellers, as soon as they receive the signals, shoot laser guns, the duel is fair (see above for a justification). Likewise, if the signals are mechanical and the guns are also mechanical, no problem, either, the duel is fair. But my concern appears when we mix things (light signals with mechanical shots, for example).
I know the difference only arises at relativistic speeds. But why is speed important? That is a difference, no doubt: low speed is not the same as relativistic speed. But what is the logical link with the resolution of the case? Why and how does the difference become relevant for these purposes...?
A possible answer is as simple as this: as the MM experiment proved, that is the way it is, all laws of physics, mechanical and electromagnetic, are invariant under the LT. This is legitimate. The basis is an observation and the explanation is intuitively appealing. 99% of our lives is based on this combination observation/intuition that works. You don't need to convince me that this is right. I believe it!
I wanted, however, a slower approach, based on logic, step by step. I don't know how to do it and can only traverse that path guided by experts. Of course, this is only for whoever feels like doing the exercise.
  • #148
Hello saw.
Quote:-
---I know the difference only arises at relativistic speeds.---
Rerlativistic effects apply at all speeds. They are of course very much samaller at low speed and in everday situations can be ignored.
Matheinste.
  • #149
Thanks a lot, for the precision, Matheinste. The term I used was of course wrong. I meant what you state, that I to say, that the difference is so small at non-relativistic speeds, that we don’t realize it is there, we don’t perceive it. I will soon explain in more detail what I meant. But any other correction is welcome.
  • #150
I correct myself a little more. Let us continue focused on the example. The referees have dissenting views as to the simultaneity of the two events, arrival of the light signals to the Front and the Back dueller.
Who is right? The author’s explanation (adapting the names) was as follows:
“Einstein’s unexpected answer is that they both are (…) they simply have different perspectives on the same sequence of events. The shocking thing that Einstein revealed is that their different perspectives yield different but equally valid claims of what events happen at the same time. Of course, at everyday speeds like that of the train, the disparity is small –Saw claims that Front got the light less than a trillionth of a second after Back- but were the train moving faster, near light speed, the time difference would be substantial”
We have already discarded that the different views as to simultaneity imply different views as to the fairness of the duel. In spite of that discrepancy, the duel was fair. This has been the gist of this thread. SR does not put into question what is “fundamental”, i.e., in my view, the agreement on events and the subsequent practical solution of the problem.
Thus the concept of the relativity of simultaneity appears as a discrepancy in the outcome of measurements, which nevertheless (if combined with other coordinate-dependent values, equally relative, that are necessary for calculation purposes) does not generate a discrepancy on the occurrence of the events of the story.
In other words, relativity of simultaneity is necessary for predicting what may happen, but has no impact itself on what may happen.
If the train were moving at relativistic speeds, near the speed of light, the disparity would be much more relevant, but its meaning would be the same: we would find a higher quantitative discrepancy in the measurements, but the story would not change.
So the difference is “perceived” in the discrepancy that I, as referee on the ground, appreciate between the readings of clocks situated in my ground frame, when the signals reach Back and Front. It is not that Back and Front perceive any difference in their clocks, since of course for them their time is normal, it does not dilate and there’s no lack of simultaneity.
  • #151
That may or may not be the case. But either way it has proven itself a very useful concept
  • #152
I agree. Really, this sort of statements (“time does not exist”) look too radical and may create controversy.
What I simply mean is:
If we take, as usual, the statement that two events are “simultaneous”:
- I look at one side and what do I find? The ORIGIN of the statement = The value measured by a clock. This is a reality, an event, a fact, a truth as big as a cathedral and of course it exists.
- I look at the other side and what do I find? This value, after combination with other values, leads to the PREDICTION of another event, which is also factual and true and of course it exists.
- And in the middle? Any other event or fact or truth? No, in the middle there is nothing.
So the statement “do you agree that this judgment of simultaneity is true and correct?” must be translated into “do you agree that this measurement value, after adequate combination with other values in accordance with certain formulas, must lead to the prediction of a certain fact?”
If the values that you are able to measure happened to be homogeneous for all observers, regardless their states of motion, the formula (the Galilean Transformation) would be easy to draft and of course it would predict facts.
If the value that, in practice, you obtain varies for different observers, the formula (the Lorentz Transformation) is more complicated to achieve, but if it is well drafted and you apply it judiciously, it will have equal predictive power.
So there is nothing “onthological” here. It is not a question of saying simultaneity is relative or absolute in radical terms. It is a practical issue. Hence of course time, in spite of being a mere concept, is practical, because if it is not practical, it is not time, it is bad measurement or bad mathematics.
  • #153
Saw said:
Ok, if you wish to continue the analysis (after the turmoil created by Althon), I'll leave aside subtleties on words and put things in a less baroque manner.
What was the goal? To discuss about what “the difference in judgments about simultaneity” means, just in case it is in the interest of physics.
1) First, “simultaneous” in a given frame means that:
JesseM said:
if we have two clocks at either end of the train which have been synchronized in the train's frame using Einstein's convention, they will both read the same time when the lasers are fired next to them, but if we have two clocks on the ground which have been synchronized in the ground frame using Einstein's convention, and both clocks happen to be right next to the two duellers at the moment each fires his laser, then these two clocks will show different times when the lasers are fired next to them.
You specify the origin of the clock readings, how they have been obtained (the clocks have been synched through the Einstein convention and have ticked afterwards at the corresponding rate).
(A couple of footnotes, about obvious things, which I note just in case they are useful:
- That is important to remember, because it is part of the physical content of the definition. We do not know how variations of that convention might affect the outcome (it would depend on the nature of the variations), but let us just note it.
Well, the physically important thing about this convention is that if all inertial observers design their coordinate systems in this way and then figure out the correct equations for the laws of physics as expressed in their coordinate systems, they'll all get identical equations. This is a real physical symmetry in the laws of physics, "Lorentz symmetry" or "Lorentz invariance"; we can imagine alternate laws of physics where this wouldn't be true. Observers could choose a different simultaneity convention which would result in a different type of coordinate system, but the equations in this coordinate system would have to look different than they do when expressed in the standard SR inertial coordinate systems.
Saw said:
- The observers get different values, but it’s also true that the measurements are events and so they happen in all frames and all frames agree that they happen. Furthermore, one frame can predict the quantity of the other’s measurement.)
Yes, this is true.
Saw said:
2) Second, we must make use of the measurements of the observers for a purpose.
(Footnote: What purpose? For me, the aim of physics is “to solve problems”, like whether a duel is fair or not.
I agree the purpose is to solve problems, but I'd say it's to solve problems about well-defined physical questions like the time interval on a given clock, "fairness" is kind of a nebulous idea...if you have already defined your idea of "fairness" in purely physical terms, like "the duel is fair if each dueller experiences the same proper time between firing their own gun and the laser from the other guy's gun reaching their position", then you can use the laws of physics to judge if the duel is fair.
Saw said:
3) Third, your measurements serve their purpose by combination with other measurements.
The judgments about simultaneity alone do not serve any purpose. For example, in our case, we have to combine them with another measurement: we must determine if “both duellers have an equal amount of time on their own clocks between firing their own gun and being hit by (or dodging) the other guy's laser”. Once we do it, the trick is done. In my frame, the proper time of Back when shot – the proper time of Back when shooting = the proper time of Front when shot – the proper time of Front when shooting. So the duel is fair.
(Footnote: Both referees agree that the other has correctly applied the formula and obtained, ultimately, the right solution. Maybe you could comment on technicalities of this operation that I might have missed.)
Conclusion: both judgments of simultaneity are right, in the sense that, after due consideration of their origin and due combination with other measurements, they serve beautifully the common practical purpose.
Did I do my homework? Does this look more reasonable?
I think so...I might paraphrase this by saying that coordinate-dependent judgments like judgments about "simultaneity" in a given frame are only useful insofar as they are used in calculations about coordinate-invariant physical results like the proper time between two events on a given clock. Would you say this is a reasonable paraphrase?
Also, to respond to a bit of your most recent post:
I agree that physics cannot solve the ontological question of whether there is an absolute present. However, if all the laws of physics are Lorentz-symmetric, this does imply that there can never be any physical basis for saying one frame's judgments about simultaneity are more "correct" than any other's. So for a philosopher, this might at least be said to lend weight to the idea that there is no such thing as absolute simultaneity, just by the Occam's razor argument that we should try to avoid postulating extra metaphysical entities that have no relevance to any empirical observations. We can't prove that there's no physically undetectable "metaphysically preferred frame" whose judgments about simultaneity are "correct" in some absolute metaphysical sense, but we also can't prove that there aren't physically undetectable gremlins sitting on the shoulder of every human on the world; if there is no pressing philosophical argument for why we should believe in such entities, one can argue that it's simpler to assume they don't exist.
  • #154
This is a similar objection to the one you raised earlier with length, width, and height. I resolved it by clarifying that X must, of course, be an explicit statement containing full information. In the LWH example I said the observers were "being sloppy" if they just said "X is 4 meters long, Y is 5 meters long, therefore Y is longer than X". In reality 4m "long" is not the only relevant measurement, the observer must specify all the conditions involved in the measurement. Therefore "X is 4 m long and Y is 5 m long when X is 8 m from Y" is a full statement if X and Y are the only entities involved. This observer concludes "Y is longer than X when they are 8 meters apart". Another observer might say "X is 3 m long and Y is 2 m long when X is 7 m from Y". This one concludes "X is longer than Y when they are 7 meters apart". These aren't contradictory, they're just different.
Similarly an observer is just being sloppy if s/he declares a binary, qualitative conclusion based on only the scalar speeds. It's not an explicit statement containing all the information. In both cases, the LWH one and the speed one, the observers that come to contradictory conclusions erroneously neglect to incorporate relevant information into their conclusion. Therefore their conclusion is unjustified.
I was saying the scenario you pointed out was no different than any other in the sense that it contained no ontological contradictions.
As I tried to illustrate in the example, observers do not come to any absolute conclusions about length, width or height. They come to conclusions about if X is longer than Y "when X is this distance from Y". Comparing the different conclusions is comparing apples to oranges. One conclusion says X is longer than Y when they are 5 m apart, another says Y is longer than X when they are 8 m apart. To keep numbers out of it they could simply say things like "X is longer than Y when X is further from Y than Z". Nobody will arrive at a contradiction if they are explicit and specific.
Quantities may be frame-dependent, but two observers will never disagree about which has a greater velocity, which has greater extent in a specific direction, etc. The quantities may vary up and down but never can they cross over such that qualitative conclusions contradict.
No, I don't believe in "ghostly axes", as I stated before. I only believe that there is an objective reality (A is A) and, as such, there should be no true contradictions regardless of how you examine something. Observers only contradict because they have not been specific and explicit in their conclusions or because their premises/assumptions are wrong.
Justify this.
They will not disagree or contradict if they include all the relevant info in their conclusion.
Visualization is the only way to explain and understand a phenomenon. Mathematics is a way of describing some phenomenon. In particular mathematics can only describe dynamic concepts/processes.
You don't visualize colors at all because color is not a standalone object. Color is a concept you understand via comparison. An object is something you visualize by itself. If every entity were the same color do you think we'd still say something like "it's red"? No, we'd only have a conception of "color" by comparison.
It makes no sense to talk about visualizing colors in the first place, and even less sense to talk about visualizing colors that you can't see. Color is defined in terms of sight. It's like saying I can't visualize a table that isn't a table or I can't visualize a shape that isn't a shape.
There's no problem with not being able to see something, but it should be visualizable i.e. have shape. This is the only objective criterion for determining if something is "physical".
I have shown that in no instance do observers disagree on qualitative issues if they are explicit and specific. Except in the case of "relativity of simultaneity". In this case two observers disagree that an event was simultaneous. In all other instances observers either agree or are comparing apples with oranges.
What this tells me is that spatial locality of two entities is what's important, not temporal. If temporal locality is unimportant then we can do away with the t coordinate altogether and just talk about relative motion. Now instead of talking about AB being "simultaneous" we just say that A and B came in contact.
What's difficult about this proposal is that we have to include the relative motion of the internal machinery of the clock and the photons and this process is not well understood.
So as scientists peculiarities intrigue us and beg us to look deeper! Maybe it's just a coincidence, maybe there's no significance at all to the observation that the "relativity of simultaneity" is the only qualitative contradiction. But maybe so.
I see what you're talking about. In a "fundamental disagreement" one person is contradicting themselves.
Fred: I define red as 600nm on this device
Billy: I agree.
Fred: The device says 600 nm, therefore the light is red.
Billy: I disagree.
In this case, there's no disagreement because Billy is simply wrong. When a person invokes a self-contradiction the other person is justified in declaring them "wrong" and sending them back to the drawing board.
If nobody contradicts themselves, there are no "fundamental disagreements" as you called it.
You may not have in your sentence, but "much" is a subjective term. To grant it any rigorous meaning you have to define it. If you don't define it then the second statement carries the same meaning as the first. How will you define it? If A is going 10 m/s faster than B does that qualify as "much"? In order to define it unambiguously you will have to mention numbers.
There will be no contradiction, each one just has to actually define clearly what in the world they mean by "north, south, up, and down". Once they do they will find no qualitative disagreement.
When observers come to qualitative, binary conclusions they will not disagree unless A) They made a mistake, such as not integrating all the relevant information (such as directionality) or B) They are talking about non colocal simultaneity
A is just human error. B intrigues me.
I'm not only concerned with calculating the final answer, I want to dig out whatever significance I can find. The fact that there is only one instance where I can find a qualitative contradiction (not due to human error of course) in different frames makes me think.
In one case we have "simultaneous" events AB that everyone agrees on in every frame. In another case we have spatially separate events AC and BD that some disagree on the simultaneity of. This leads me to believe that it is spatial separation that is important, i.e. just relative motion/location. It is when entity's are colocal that "something" happens, not necessarily when they are cotemporal. Since AC and BD can be "cotemporal" in some frame but not in another, and this makes no difference in what actually happens, the "time" parameter actually seems superfluous. Colocal is always significant, cotemporal sometimes is, so why do we need the latter? What matters is, are X and Y colocal or not?
I disagree. The declaration of whether spatially separate collisions AC and BD were simultaneous or not is completely extraneous to calculating the "final result". All the observers need to calculate the final result are the pertinent numbers. In fact, one of the ways to interpret my arguments so far is that "non co-local simultaneity" is an invalid concept and spatially separate events should not be declared either way, because it has no meaning. Extending this further to colocal entities AB, we no longer need to specify a particular time (and by extension that they were "simultaneous"). The fact that these two entities are colocal depends only on their spatial arrangement and defines this "event". I conclude that the time parameter, while it may be useful for us right now because we don't understand the relative motions involved at the most fundamental level, is superfluous.
The ontological implication is that time is unlike length, width, and height. That it is not a central component to reality but rather a useful parameter.
  • #155
Full information about what? About every physical aspect of the problem? Certainly specifying the velocities of two objects doesn't specify everything physical about them (it doesn't specify their positions for example). And what's more, when you say both must agree about which velocity is "greater", you only seem to be talking about one aspect of the velocity and ignoring other aspects like the angles of the two velocity vectors.
It's not even clear what you mean by "greater" when talking about two velocity vectors--you obviously aren't just talking about the norm of each vector since that would just be the speed which is always positive, but before you argued that an object with negative velocity on the x-axis had a "smaller velocity" than one at rest. If we have only a single spatial dimension, then all velocity vectors are parallel to each other so we can just talk about positive or negative velocities on this axis, but what if we have 2 or three spatial dimensions and non-parallel velocities? You can take the component of each velocity vector which lies parallel to a particular axis and then the components will each be either positive or negative, but in this case, which has the greater velocity depends on what axis you want to use.
For example, suppose we have an x-y-z coordinate grid, and we break down two velocity vectors into their x and y and z components. For example, object A has Vx = 5 meters/second and Vy = -3 meters/second and Vz = 0 meters/second, while object B has Vx = 4 meters/second and Vy = 12 meters/second and Vz = 0 meters/second. Obviously object B has a greater speed in this frame, but which has a "greater velocity"? The x-component of A's velocity is greater than B's, but the y-component of B's velocity is greater than A's. So do you claim there is some absolute truth about whether A or B has a "greater velocity" here, where "greater velocity" does not just mean "greater speed" (i.e. greater norm of the velocity vector)? If so, what is it? Please give me a specific answer to this question about whether A or B has a greater velocity here.
Also, even if we choose to focus on a particular axis like the x-axis, you didn't address my point that simply by rotating the x-axis by 180 degrees, a velocity vector which was previously in the -x direction of the old coordinate system can now be in the +x direction of the new one, whereas simply changing the orientation of a frame's x-axis without changing the frame's velocity won't cause you to change your judgments about which objects are at rest. So if in the first coordinate system object A has a negative velocity on the x-axis and object B is at rest, then by rotating the x-axis 180 degrees, now object A will have a positive velocity on the x-axis while B will still be at rest. If you claim there is some objective truth about which object has the greater velocity along the x-axis, then once again it seems you must believe in some sort of ghostly "true" x-axis.
Your comment about "greater velocity" seems unclear as I discussed above. And in SR different coordinate systems do disagree about which of two objects has a greater extent in a specific direction, because of length contraction. Even if you think there is an absolute truth about which frame's judgment is "really" correct, do you disagree that according to the standard way of defining SR coordinate systems, disagreements between coordinate systems about which of two objects has a greater "length" are quite possible?
But you don't believe that certain quantities, such as speed, represent "objective realities", and thus you don't believe there need to be objective truths about which object has the greater speed--is that right? If so, why can't you accept the possibility that quantities like velocity or length may also fail to represent "objective realities"?
altonhare said:
Justify this.
The "procedure I discussed above" was just the standard one for constructing inertial coordinate systems in SR, and the result is that the coordinates assigned to the same event by different observers are related by the Lorentz transformation. Do you not understand that under the Lorentz transformation, even if two coordinate systems have their spatial axes oriented the same way, if the two coordinate systems are in motion relative to one another they can disagree about which of two objects has a greater length? If so I can give you a numerical example, if that's what you're asking for. But if you're asking me to justify something else, please be specific about what it is.
But by "visualizable" do you mean actually being able to form a visual image of the shape in your mind's eye, or do you just mean that the shape can be defined using the language of mathematics? If we have a cartesian coordinate system with 3 spatial axes, the shape of any object can be described mathematically by giving some equations which tell you which points lie on its surface; for example, the equation x^2 + y^2 + z^2 = 1 describes the surface of a sphere with radius 1 centered on the origin, all points which lie on its surface (and only those points) will have coordinates that satisfy that equation. Similarly we can describe the shape of objects in a hypothetical 4D space with equations of 4 variables, like the surface of a "hypersphere" which has equation x^2 + y^2 + z^2 + w^2 = 1. We can't picture such 4D objects visually because our brains have become adapted to find 3D space intuitive, but I imagine if you could somehow take the brain of a newborn and feed it sensory inputs from a simulated 4-dimensional body in virtual reality, as it grew up it would be able to visualize 4-dimensional shapes. Visualization isn't a very rigorous criterion in any case because it depends on the contingent details of our biology and history, whereas mathematics allows us to define the notion of "shape" in a completely rigorous way that doesn't depend on what we can visualize (and arguably a blind person can't 'visualize' any shapes at all, although I suppose they could imagine what it would feel like to run their hands over it).
  • #156
If you are the observer that sees the ball going 15 m/s down and see your counter part going 25 m/s down, wouldn't you agree that your counterpart would measure the ball going at 10 m/s up relative to him? Don't you agree that in this case there is no quantitative disagreement once the observers clearly define the context of their measurements to one another.
Another example: Imagine looking at a 2 dimensional square in three space. There are two observers, one(1) looks on perpendicular to the plane the square is in. The other observer(2) is looking at an angle so he sees an odd looking rectangle. (2) would necessarily compute a smaller area than (1) since his view is screwed up. Say observer (2) gets .5 m2 and (1) gets 1 m2. You may think that (1) has the correct area, but notice. If (1) did some math to determine how his answer would change if he were looking from (2)'s position, don't you agree that he would get .5 m2 there by agreeing that (2) measured the correct value based on his view? So the clear contridiction in their quantitative measurements is reconciled once you transform properly to between the two frames in this case. Agree so far?
  • #157
Maybe you will like "many-fingered time"? Like in Zeh, p187, http://books.google.com/books?id=4yUu-simAhMC&printsec=frontcover#PPA187,M1, or Nikolic, http://arxiv.org/abs/hep-th/0501046.
  • #159
Miscommunication between people who have different educational backgrounds and are used to different specialised languages is unavoidable, but both specialists should be talking about the same thing. If a good lawyer gave you an account of what “fairness” means for legal purposes, you would immediately recognize in that picture your own physical definition. Likewise, if you develop in full that definition before the court, the judge should understand you as if she were reading an Act. There is no possible option, because ultimately both understandings, if well constructed, aim at the same target.
But there is still something I would like to clarify. I am the layman who has the practical problem and you are the specialist who must sell a convincing solution to me. You cannot demand that I accept as solution that the game is fair only because it conforms to a certain technical rule internal to a theory, the theory must also appear to me consistent and reasonable. Of course, if I ever dared to raise objections, I should not be imprecise, ignorant or obtuse. First, I must precisely define my needs, which practical problem I present to you. Second, I must make an effort to understand the basics of your theory, otherwise you would feel like talking to a wall. Third, even if there are still some obscure points in the back of my mind, as long as the overall picture looks reasonable, I will rule on the basis of what you propose.
This is what has happened so far. I mean by fairness that the two duellers have equal opportunities. The outcome of the duel must depend exclusively on their skills and how they use them. We discard that there are external distortions, but at least the rules of the game must be fair: the fact that the train moves wrt me and that the signals for shooting are light signals does not entail different opportunities for the duellers. Furthermore, based on my experience, I have identified a number of situations where, for me, the game would not be fair and asked specific questions about them. You have given your opinion and I have understood it. So I rule without any doubt that the game was fair.
But imagine that in another case, where a new configuration is introduced, I had concerns, because it seems to me that the rule "the duel is fair if each dueller experiences the same proper time between firing their own gun and the laser from the other guy's gun reaching their position" might not meet my needs.
Here the simile of the referee is not useful any more. Think of me as the legislator. I must establish some handy rule for referees to follow automatically. Would you agree that, in that case, the role of the scientist is to overcome my doubts and convince me that his rule must become the law? Would you agree that my needs are your needs and my purpose is your own purpose?
I agree that 99% of the subjects of the human law cannot be solved this way, because actually the needs are too nebulous and the word “fair” is a good example of that. But here we have a simpler case where “fairness” has been precisely defined and so it seems that the human law must be equal to the physical law. Eventually, it might happen that the physical law does not solve the problem to the maximum degree of certainty, but in that case I would also adopt your rule as the law, because that is the best we can do, and we would still have tried to achieve our purpose as best as we could. Ok?
I'll comment on the other points later...
  • #160
Please tell me if this is a reasonably approximate paraphrase in layman terms:
On the basis of the measurements obtained this way, observers draw their coordinate systems, that is to say, they make a pictorial representation of what happens, a geometry. The geometry itself would suffice: you can visualize whether events will happen or not. Another way to express it is through mathematical equations. All these languages do the trick: (i) you can predict on the basis of the values in your coordinate system which events will happen and (ii) you can transform from the “dialect” of one coordinate system into another.
The only thing I miss here is some emphasis on the physical characteristics of the instrument. Nowadays:
- Time rate is best measured with atomic clocks, whose “ticker” is electromagnetic radiation oscillating in round-trips (a more sophisticated version of the “light clock”?). Thus the second is defined as “the time needed for a cesium-133 atom to perform 9,192,631,770 complete oscillations”.
- Distant clocks are synchronized with the Einstein convention: the trip time attributed to the distant clock is the time (ideally, measured by an atomic clock) that light takes to reach the distant clock and return, divided by 2.
- The metre is defined as “the distance traveled by light in free space in 1⁄299,792,458 of a second”, as measured preferably by an atomic clock. Is this measurement also made after a round-trip? I presume so.
I find little literature over the subject. But it seems both space and time are measured in a manner that has three features:
(i) the protagonist is light (or any electromagnetic wave);
(ii) the quantitative assessment is done after a round trip; and
(iii) the measurements are intertwined.
Could we thus say that we talk about “Lorentz symmetry” because we use a “Lorentz instrument”?
  • #161
JesseM said:
Also, to respond to a bit of your most recent post: I agree that physics cannot solve the ontological question of whether there is an absolute present.
Well, I do not really claim that there “is” an “absolute present” as a real entity, although it is true that I may have led you to think so due to imprecise language. I will explain below.
I agree. I would even eliminate the “if”. Based on the evidence that you, experts, have provided to me, I long ago convinced myself that the laws of physics are Lorentz-symmetric.
I thank you for the idea to put at the beginning of the post my personal word definitions. This sounds like declaring the “variables” beforehand in programming languages. Their name is just a helpful reminder, what is important is the role or function that they play in the logic of the code. I will explain what I understand by “real” and “conceptual” and afterwards you can name these “variables” as you wish.
“Real” = matter particles and photons (or wave-particles or whatever they are), that is to say, the actors of the play, which “exist”, and the interactions between them or events, which “happen”. (The distinction, I admit, is somehow artificial, since everything is moving inside matter, causing continuous events, “things are events”, “nouns are verbs”, but it can serve as a start). This is the fundamental thing. All observers should agree on this, no matter their different perspectives (e.g.: position or state of motion).
“Concepts” = mere logical tricks that we invent to solve practical problems. We have some facts (eg: the measurements) and we want to predict other facts that are interesting for some practical purposes. How do we establish the link between the former and the latter? We apply logic and conclude that the measurements (of facts) necessarily lead to the predictions (of facts).
The confusion arises only if we get trapped in our own idea and start thinking of the “concept” as if it were a photon or an oxygen atom or a pretty lady, and then we ask each other: “do you agree that absolute or relative simultaneity exists?” I am sorry. I will not answer that question, unless you be more precise. There may be other ways to put it, but I have decided to reserve the word “exists” or “is” for the “real” things, like a photon or an event. I do not apply it to a “concept”. Yes, somehow, concepts exist, in my mind, and they are very close to reality, since they play with real facts as input and produce predictions of facts as output. But when referring to a concept, one must not forget what it serves for: a concept is valid if it relies on real facts and logically predicts real facts. Thus I would request that the question is reformulated as follows. For example: “do you agree that this concept is useless because its input is not found in reality?” or “do you agree that this concept is treacherous, because it derives bad outputs on the basis of a faulty logic?”
I think you will fully agree with this “code” even if we may have different preferences for the names of the “variables”, wouldn’t you?
Now let us be more practical. I would paraphrase your comments in my own words, as follows:
1) The concept of absolute simultaneity is useless, because all measurements of simultaneity are always frame-dependent.
2) Your definition of reality is in itself a concept. You are introducing in it the idea of simultaneity. If someone says that certain things exist right “now” and those things are some distance away, he has to measure it through physical means. If two observers measure the time coordinate of an event, they will get relative values. So that is not part of what is valid for all observers.
I basically agree with those comments (if they reflect at all what you mean) but have only some partial objections, which may be relevant for our practical problem (was the duel fair?) in the variation that I have commented before: the duellers receive light signals and shoot normal bullets.
  • #162
I once read this opinion: “Absolute simultaneity exists. Just clap your hands and… is the universe there? It is, of course”.
I think the author had a point, but he created much confusion by introducing a spurious visitor, a concept (simultaneity), in the definition of reality. This mistake may be unavoidable to a good extent, because we think with concepts but, if possible, it should be avoided. At least, we shouldn’t need simultaneity to understand what reality is.
Let us forget about time “for a while” and make a mental effort to describe a physical situation without its support.
You are blind. Someone throws to you a ball. Unfortunately, the knowledge that the ball is approaching will not magically appear in your mind. We are also physical objects ourselves and we can only learn anything about our peers by physically interacting with them. So you must wait until the ball touches your chest and this information is transmitted to your brain. Now you conclude: “the ball has interacted with me, ergo it exists, it is real”. It is regrettable that you had to wait for the interaction to reach this conclusion, because the ball existed anyhow, even if it had not yet interacted with you, but we are physical and that is the way it is. At least, the important thing is that you have realized that the ball exists, reality exists!
Now the ball bounces off your chest. Distance is created between you and the ball. Does it exist? It might have been blown off, but then it would be still somewhere in another form (mass-energy is conserved). Anyhow, like in our example of the duel, we can imagine that all external influences (including gravity) have been removed. So the ball will keep moving forever in a straight line as a good inertial frame. Thus the fact that there is distance between you and the ball does not change anything. It should not make you change your mind. If you had concluded that the ball existed when it interacted with you, there is no valid reason why you should start thinking that it does not exist after the interaction.
The “impossible negative proof argument” (I cannot prove there aren't physically undetectable gremlins sitting on the shoulder of every human on the world) is not applicable here: we haven’t ever, ever physically detected any such gremlins, but we have physically detected the ball. So the assumption that it exists is a logical inference of a physically detected fact.
What if you want to physically check that the ball exists? Strictly speaking, you would have to interact with the ball, in one of these two ways: an assistant of yours runs into the ball, interacts with it, and he travels to your place to deliver his message (yes or no, it does or it doesn’t) or you send a messenger (e.g.: a light beam) to reflect against the ball (if it comes back, it is because the ball was there; if not, it has disappeared or changed its trajectory). In the ideal display that we have chosen, the answer should be always positive, by sheer logic, because we have eliminated from the stage any external distortion factor.
Certainly, there may be “internal” distortion factors: if the ball is a muon, has it disintegrated or not? Well, in that case, the answer would even be beyond the reach of logic. I would still claim that the ball exists in some other form (mass-energy conservation principle), but I could not argue on the basis of logic that it exists in its initial form (a muon). However, the stage of the duel has been arranged so that such kind of concern will not arise, since the actors are more enduring and the distance is small: a photon or a bullet will not disintegrate in the short trip required to traverse the length of the car or the distance between the mid-point of the car and one edge. Thus logic is still helpful in this particular context… for what purpose?
Yes, all this looks very interesting from a spiritual point of view: you may feel sure that reality (a Being) is there, in some form or another, and that a ball is there, keeping its form, in a certain pre-arranged physical display, but can you use that certainty for the purpose of solving problems? Is that useful for the physical problem that is waving its hand before you and me?
In our current investigation (there are light signals and the shooters shoot bullets; I am the referee on the ground and I have to rule if the duel is fair, guided by physicists), is it relevant at all?
It is my impression that the answer is definitely YES. It is PHYSICALLY relevant, since it helps to define the problem in purely PHYSICAL terms. The problem was “equal opportunities”, in the legal jargon. What is its translation into the language of physics? Have I said anything at all that that makes you doubt about your initial definition?
  • #163
Your definition was:
Since my doubts arise with bullets, we would have to adapt it like this:
"the duel is fair if each dueller experiences the same proper time between firing their own gun (=receiving their own light signal) and the bullet from the other guy's gun reaching their position"
For example, we first calculate the “proper time” of Back (= difference between his own clock reading at reception by his retina and brain of the signal and his own clock reading when he is wounded). We do the same for Front. Right? If those two intervals are identical, we conclude the duel is fair…
But is it so automatic? Most probably the “proper time intervals” of both duellers will be identical. But I am not sure whether that will prove that the duel is fair.
I had said: I, the judge, want to create a temporary sanctuary for discussion, where we only talk about “reality”, so as to define the problem itself in terms of pure “reality”, without being contaminated by any “conceptual” prejudice.
If you now enter the room with a clock in your hands, a mild judge will remind you of the rules of the discussion, but a tough one might accuse you of contempt to the court.
It is a question of methodological approach. The reading of the clocks is a measurement. In the case of clocks, a measurement of change: a ticker moves within a box or counter and every time the ticker touches a wall of the box or, if you wish, completes a full oscillation by hitting back the place of departure, some mechanism in the box perceives it and counts one unit of change. That is one thing. Another thing is whether this fact is logically linked to the resolution of the problem. That is a judgment. If the judgment is logically sound, we can say that the events of the instrument (or set of instruments whose readings are combined in a complex reading through equations) have mirrored the events of the reality we are interested in and thus we can construct the following idea: for the purpose at hand, it is “as if” my clock were a perfect mirror of what happens in the car, it is “as if” my clock contained the film of the story. Please look at it and you will see a video of the duel. Yes, a well constructed “concept” is a faithful picture of reality. Consequently, for shortness, in common language we talk as if it were the reality it is aiming at reproducing. But a bad concept is mocking at reality, it is caricature of reality. And that is precisely the question we are trying to ascertain. Therefore, you cannot introduce the instrument and its concept in the definition of the problem, since then you are begging the question.
Think of this. You are virtually telling me: “I know that a certain fact will happen for sure, so please phrase your question so as to ask whether that particular fact will happen, since that way I will ensure that the answer will be positive and I will confirm my original prediction that the game is fair…” That is not fair!
Therefore, I would prefer to keep pushing to define the problem in terms of the “real” events or physical interactions that happen inside the car. (It is not that the clock readings are not real; they are, but they are not the "real-life" events whose judgment has been brought before the court.)
“Opportunities” is the occasion or possibility to do things to harm and avoid being harmed.
These things that the duellers can do (e.g.: send other projectiles to intercept the bullet, produce a shield to stop it, step aside or duck down…) are instances of interactions with the environment. We can call them the tricks. The more you have, the better.
Second, the number of tricks that you can carry out is determined by two other interactions:
- You can start doing your tricks when you interact with the signal, but the signal is produced by another interaction, its creation by the referee through some physical operation.
- You cannot do any more tricks when you receive the shot, which is also generated by another physical interaction.
In conclusion, I would propose the following definition of the problem in physical terms:
"this particular duel (light signals, shooting bullets) is fair if each dueller can do the same number of physical interactions to avoid being shot, no matter if there is a difference between the physical nature of the signals for shooting (light) and the signals for ceasing to shoot and die… (bullets)"
Or something like that, I don’t know. I would need some feedback… Does it make any sense for you? For me, it is roughly a good legal definition, although I doubt about the details of the wording. Do you find that it is a reasonable physical definition, as well?
  • #164
Let both duellers have identical pacemakers.
  • #165
Yes, that is insightful. Let us situate the discussion on the physical characteristics of the "real-life" events, on the one side, and on the physical characteristics of the "instrumental" events, on the other side. To the extent that the latter match with and mirror the former, we'll have a good theory. I know that the answer is affirmative, since SR is at the root of moderns science and modern technology. Otherwise I would not be writing in my computer! But it seems that approach, on top of being physical, is pedagogical. It permits better communication between scientists and laymen. It helps a referee, like myself, render a fair judgment, with a reasonable motivation. Otherwise my resolution would be annulled due to lack of motivation!
  • #166
Before I forget this idea, just a hint (I’m thinking aloud): maybe, even if there IS a difference between the behaviour of the measured objects in real life, you can measure and plot that behaviour with a light instrument, because that is fully IRRELEVANT for the measurement purposes; but maybe, anyhow, we have to accept that the best instrument is only almost perfect, it leaves a tiny amount of uncertainty… We will see. What we should do now is allow into the court room the technicians with their different instruments and analyze how they work, starting with the classical team and their mechanical clocks, in order to ascertain their pros and cons.
  • #167
Back in the wordy days of physics, I don't think Einstein took one tenth as many words solidify what seems to be argued and unargued here. Did I get lost on the philosophy page?
  • #168
Hello all.
With regards to simultaneity. While browsing past threads I came accros Simultaneity which has the secondmost number of replies (280) and the thirdmosty munber of views (16,900). In #18 Dalespam says:-
--- The point is that simultaneity is an artificial construct arising from the definition of a coordinate system, not something objectively real in its own right. Fundamentally it appears that the universe doesn't care about simultaneity, only about causality. Two simultaneous events cannot be causally connected, so what does it matter if one happened before the other? On the other hand, a cause should always come before an effect, and this is exactly what we see in relativity. A cause will preceed the effect in all reference frames, and for the rest it doesn't really matter. -----
I that is a very good way of putting it.
In such scenarios as those under discussion, simultaneity seems to matter in the sense that we have introduced a human element of fairness/right and wrong.
Deciding if two spatially separated events are simultaneous is merely a case of applying the agreed definition. A problem which arises in some of these proposed puzzles is that "making two events happen simultaneously" can only be done by making them both causally connected to a single event, such as the throwing of a switch, to set the chain of events in motion. The decision on the simultaneity of two spatially saparated events is an artificial construct and "constucting" the simultaneity of events is engineered. You cannot engineer a situation where things happen without having control of them, and this implies a causal connection. So I think it may be fair to say that unless the events happen to be simultaneous by chance, you cannot "construct" the simultaneity of two events unless the simultaneity is engineered from a single event/cause, or by some other mechanism constucted by a conscious entity. The last proviso is added as a get out clause should my belief that simultaneity cannot be manufactured in other ways than from a single event causally connected to both the events that are required to be simultaneous is wrong.
Note that in Eistein's train and embankment thought experiment the lightning strikes just happen to be simultaneous, they are not "consructed" to be so.
Matheinste.
  • #169
- --- The point is that simultaneity is an artificial construct arising from the definition of a coordinate system, not something objectively real in its own right. Fundamentally it appears that the universe doesn't care about simultaneity, only about causality. Two simultaneous events cannot be causally connected, so what does it matter if one happened before the other? On the other hand, a cause should always come before an effect, and this is exactly what we see in relativity. A cause will preceed the effect in all reference frames, and for the rest it doesn't really matter. -----
Welcome back, Matheinste, and thanks for the quotation. I am just a little wordier, maybe due to my idiosyncrasy, but I fully agree with this sentence:
“simultaneity is an artificial construct arising from the definition of a coordinate system, not something objectively real in its own right. Fundamentally it appears that the universe doesn't care about simultaneity, only about causality.”
But my doubt is still the practical problem I have posed.
Well, I think I have phrased the problem in a manner that is purely practical and physical. See my post #163.
Rather, I believe that refusing to answer this problem would amount to closing the doors of physics to a physical issue, for a sort of metaphysical reason = thinking that a concept hits at reality, due to some mysterious axiom, and refusing to discuss the logic of that axiom. Because, if you have been patient enough to read the whole lot of words, are you sure that the answer is clear? If so, why don’t you share it with us? If you were in my court room, I wouldn’t throw you out of the court, because I think that a physical problem is a legal problem. Now I am in your forum. Would you throw me out of it because you think that a practical, every-day life problem is not a physical problem?
  • #170
Something that is "physical" is something that is agreed on by all reference frames, ie. frame invariant quantities. The "proper time" is one such invariant. In SR, the lengths of 4-vectors are invariant.
However, what is invariant differs from theory to theory. In Newtonian physics, it is the lengths of 3-vectors that are invariant.
Which invariants are more real? That is a matter for experiment, and so far it seems that SR's reality is more real that Newtonian reality.
Within SR, there is the concept of an ideal clock, and experiments indicate that atomic clocks are physical instantiations of the theoretical ideal clock. Are biological processes ideal clocks? Strictly speaking, I don't think we know. However, it seems a reasonable assumption to make, and it is a standard assumption that is made in the SR solution of the twin paradox.
  • #171
The "proper time" is one such invariant. In SR, the lengths of 4-vectors are invariant. However, what is invariant differs from theory to theory. In Newtonian physics, it is the lengths of 3-vectors that are invariant.
Ok, you are telling me that “equal number of ticks” (the proper time interval invariant) = “equal number of tricks” = “equal number of actions that each dueller can do to avoid being shot”. Right?
I just ask: for which physical reason will that happen? You say: this is a true prediction because it is confirmed by experiments. I agree that this is the way for physics to operate, since Galileo released it from pure speculation…
But then the distinction between the behaviour of the light signals and the behaviour of the bullets is totally blurred out. What do we do then with all the introduction to SR: the difference between mechanical objects (which take the motion of the source) and light (which doesn’t)…? Has SR showed that, in the end, the motion patterns of matter and light are fully equivalent, the only difference being that light is much faster?
Imagine that the referee sends, at the same time, light and mechanical signals to the duellers and that the latter shoot with both bullets and laser beams. It just happens that the light travels both ways through a tube of a certain “imaginary” material. Light slows down when crossing certain media, as a function of their index of refraction. The bullets are as fast as can be achievable and our imaginary material has an imaginary refraction index such that, when we observe the light traveling to Back, such light is slowed down to the point of being always aligned with the corresponding bullet. If we observe the light in the other direction or in its way back, will it also be aligned with the bullet?
What is SR’s answer to this thought-experiment?
If the answer is yes, is there any hint at the reason? For example, I’ve sometimes read that SR proved that, in the end, "matter moves like light", since all internal forces holding our atoms and molecules together are electromagnetic. I’ve also read that the same applies to other interactions, like weak interactions (eg: decay of muons), thus showing that all fundamental forces of nature are substantially alike and may one day be unified, since they follow the same rules that have been obtained analyzing the properties of light. Is it so?
  • #172
Yes, that's right, but that's not what I was telling you. If you work in an inertial frame, say the frame on the train, you can define "fair" in whatever way you want. For example, you could define it so that it is fair even though Front always dies. Now if you are worried that your definition of fairness is frame dependent, then what you have to do is translate your fairness criteria in terms of relativistic invariants. If you specify your criteria in terms of relativistic invariants, referees in all frames will always agree on whether some set of events in spacetime match that criteria. I believe this is what JesseM was doing when he proposed a set of criteria in terms of proper time.
Hmmm, that's not the way I learned SR, but it seems right to me.
My understanding is that light in a medium is just like a bullet. SR makes a distinction between light in a vacuum and everything else. For everything else, like a bullet or light in a medium, if you run fast enough you will catch up with it. For light in a vacuum, you can run as fast as you want, and it will always go away from you at "the speed of light".
Matter is massive so it moves slower than light. When light interacts with matter, things are a complicated jumble such that light seems to slow down. Light in vacuum is special. However, it is experimentally true that all the laws of physics governing light and matter share the same symmetry of Lorentz invariance.
  • #173
Yes, JesseM’s definition was a substantial improvement vis-à-vis Greene’s. The physical solution to a physical problem cannot be frame-dependent. But I wanted to push a step further. It might theoretically happen that this result (the number of proper ticks for each dueller is identical) is always measured because the instrument is not precise enough and does not catch deviations from that rule. It might happen that, under normal, every-day circumstances, the proper times intervals are always identical, but, under extraordinary circumstances we are not accustomed to, we discover that the intervals are not identical. Hence if we do not want to be blinded by prejudices, we must look at the physical causes. I can list one thousand examples of scientists who asked themselves these “why questions” and thus logically predicted that the experimental results would be different with better instruments or under different circumstances and such statements were later confirmed by better observations.
The classical example of Galileo’s discovery of the principle of equivalence is illustrative. Should we throw Galileo out of a physics forum? By the way, Galileo reasoned with logic and, yes, he was quite wordy.
Therefore, I say: let us look at the causes. We have, on the one hand, the “warnings” (light signals) and, on the other hand, the “shots” (bullets). Tell me “something”, something at least about the physical nature of the interactions that cause the motion of the light signals and of the bullets. I do not need that we find here the ultimate explanation of those interactions. I just want to be told if, for you, the nature of the interaction is in both cases such that, for motion purposes, light signals and bullets behave identically. If the answer is yes, we can still discuss a little more why. If the answer is no, there may still be a (smalller) room for discussion.
Please look at the problem as follows: SR is telling me that, even if different observers observed the “warnings” to be behaving unequally, they also observed the “shots” to behave unequally, so that one thing compensates the other and in the end they all agree that the duellers disposed of the same number of “ticks” to do their “tricks”. I have no problem with that if the “warnings” and the “shots” are both made of the same thing (light). But when the “warnings” are light and the “shots” are bullets, if you wish to maintain the same solution, you must then hold that light and matter, at least in so far as motion pattern is concerned, are analogous or analogous under certain circumstances. It may be so. But please say it expressly.
Maybe you were taught, as an introduction to SR, Galileo’s description of the ship, where “nothing changes” = the laws of physics are the same =
You will discover not the least change in all the effects named, nor could you tell from any of them whether the ship was moving or standing still.
But in the next paragraph he also specified a physical cause for that description:
The cause of all these correspondences of effects is the fact that the ship's motion is common to all the things contained in it, and to the air also. That is why I said you should be below decks; for if this took place above in the open air, which would not follow the course of the ship, more or less noticeable differences would be seen in some of the effects noted.
I am far from postulating that light moves through a medium (a hypothetical aether). Maybe it does not take the motion of the source for another reason, namely because it “self-accelerates” itself (the electric field creates a magnetic field, which in turn creates an electric field) and this self-acceleration follows a pattern that is independent of the motion of the emitting or reflecting matter. Both models may be analogous for practical purposes. But if you believe that any of them is applicable to the light “warnings”, then you have to explain if it is also applicable to the mechanical “shots”.
Does SR postulate that the mechanical shots follow a Galilean pattern of motion when they are at rest in a frame and, as their speed increases, their motion pattern progressively conforms to light’s motion pattern?
It is clear that in vacuum light is faster than anything else, while in media it may not be. But the question is: As the light warning is slowed down by the medium, does it mean that it progressively adapts its motion pattern to conform to the mechanical bullet’s motion pattern?
All these questions look quite physical to me. Or shall we come back to the old days of physics where they were left in the hand of philosophers? Shall I, the referee, decide on my own, without the advice of the experts?
  • #174
Atyy, needless to say that some ironical comments in my latest post were not addressed to you, but to the opinion that this just philosophy...:wink:
  • #175
Thank you!
That was indeed a very long thread! I congratulate you for your browsing stamina. :smile:
