- #36
PeterDonis
Mentor
- 47,631
- 23,898
JohnnyGui said:I'm only focusing on physical length of the LIGO arm
And how is "physical length" defined? You need to pick a simultaneity convention, so you can identify which events on the worldlines of the different parts of the arm happen at the same time. That means you have to pick coordinates. There is no "length" independent of coordinates. In spacetime, independent of coordinates, the LIGO arm occupies a "world tube"; a world tube doesn't have a "length".
Note that such a choice of coordinates was necessary in the meter stick case too; I said I was assuming standard Schwarzschild coordinates. The meter stick does not have a "length" independent of coordinates; it only has a spacetime world tube.
JohnnyGui said:if you correct the formula for calculating the length of the arm and take into account the actual paths of the light rays in the curved space caused by the gravitational wave, would you calculate the same length as the initial length of the LIGO arm in the absence of a gravitaitonal wave?
This doesn't make sense. LIGO is not observing the length of the arm from a distance, using light rays emitted from each end and looking at the angle between them. It's observing the interference pattern caused by light rays bouncing back and forth along two perpendicular arms.
