- #106
PeterDonis
Mentor
- 46,643
- 23,194
timmdeeg said:Do you agree that the change of interatomic distances in a bar which is falling radially towards a black hole is so tiny that its length increase is negligible compared to the case were there was magically no electrostatic bonding between the atoms of the bar?
This is a very different case from the case of a GW passing through a bar. In the GW case, the change in the metric coefficients is small (at least for all the cases under discussion in this thread) and periodic--which means it doesn't build up over time, it just oscillates. So the induced stress in the bar stays well within the elastic limit of the bar--i.e., it never permanently deforms its structure.
In the case of a bar falling radially into a black hole, the change in the metric coefficients does not oscillate--it builds up over time, getting larger and larger. That means it will eventually stretch any material whatsoever beyond its elastic limit and start permanently deforming it (and ultimately tearing it apart). That is because relativity imposes a finite limit on the tensile strength of materials (roughly, that the speed of sound in the material can't exceed the speed of light), whereas there is no limit on the stretching that can be induced by tidal gravity on a bar oriented radially when falling into a black hole (the stretching increases without bound as the singularity inside the hole is approached). So this case is very different from the case of a GW, and should be discussed in a separate thread if you want to know more about it.
