Lim x->0 (arctan(x^2))/(sinx+tanx)^2
  • Thread starter Thread starter skyturnred
skyturnred
lim x→0 \frac{arctan(x^{2})}{(sinx+tanx)^{2}}
OK, so at first, the form is \frac{0}{0} so I use L'Hopital's rule. I get the following as my answer.
lim x→0 \frac{1}{1+x^{4}}*\frac{1}{2(sinx+tanx)(cosx+sec^{2}x}
But the form is not 0/0 and I cannot figure out what to do at this point. I have tried expanding out the (sinx+tanx) with the (cosx+sec^2x) to no avail.. and I can't really think of what else to do.
Thanks in advance!
You did not differentiate arctan(x^2) correctly. Don't forget the chain rule!
Stimpon said:
You seem to have just made a simple mistake, you should get x on top, not 1. Also that 2 shouldn't be there.
http://www.wolframalpha.com/input/?i=(arctan(x^2))'/((sinx+tanx)^2)'
Thanks! But now I have another issue.
When I fix my error, I get
lim x→0 \frac{x}{(1+x^4)(sinx+tanx)(cosx+sec^2x)}
This is of the form 0/0
I tried to expand the bottom and I get a HUGE equation, a very very long equation and I must be doing this wrong. Any ideas?
PS: This is the equation I get.
\frac{x}{sinxcosx+sinxsec^{2}x+sinx+tanxsec^{2}x+x^{4}sinxcosx+x^{4}sinxsec^{2}x+x^{4}sinx+x^{4}tanxsec^{2}x}
I really doubt that I am expected to use hopitals rule on that.. even though it wouldn't be too hard
What's lim x->0 of 1/((1+x^4)*(cos(x)+sec(x)^2))? That part is not indeterminant. It just approaches a constant. Just do l'Hopital on the indeterminant part.
Oh, I completely forgot you could do that! I get 1/4 is the answer to the question.. which I hope is right. And thanks so much for your help!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
