Lim x->0 e^(-1/x^2)/x^3 (Don't Understand Why I Can't Do It)
  • Thread starter Thread starter EstimatedEyes
The limit lim x->0 e^(-1/x^2)/x^3 is evaluated to show that the function f(x) = e^(-1/x^2) is not equal to its Maclurin Series at x=0. The discussion highlights the application of L'Hopital's rule due to the 0/0 indeterminate form, but repeated differentiation leads to the same form, complicating the limit evaluation. Participants suggest simplifying the expression by rewriting it as e^(-1/x^2)/x^3 = x^(-3)/e^(1/x^2) to facilitate further analysis. There is also interest in generalizing the limit for e^(-1/x^2)/x^n as n approaches 0 for integers greater than 2. Ultimately, the limit approaches zero, illustrating the behavior of the function near x=0.
EstimatedEyes
It is part of a larger problem, but the only hangup I have had is computing this limit.
lim x->0 e^(-1/x^2)/x^3.
It's to show that the function f(x) = e^(-1/x^2) (when x is not 0) and 0 (when x is 0) is not equal to its Maclurin Series. I know that if I can show that the derivatives of f(x) are equal to zero when x=0 (a) then I can prove what the problem is asking. Showing why the derivatives equal zero has been a problem thus far though...
I put it into Wolfram Alpha and know that it's equal to zero, but I don't know how to get it.
I know that L'Hopital's rule applies because it is 0/0
so:
((2/x^3)*e^(-1/x^2))/(3x^2) = 2e^(-1/x^2)/3x^5
Doesn't this pattern keep repeating giving one 0/0 no matter how many times one differentiated? It will always have e^(-1/x^2) on the top and some power of x which will continue to grow on the bottom. How can this limit be computed? Thanks!
As x \rightarrow 0 which goes to zero first? e-1/x2 or x3?
I don't quite understand what you're asking; Both go to zero and I don't understand how one can do so first...
\frac{e^{-1/x^2}}{x^3}=\frac{x^{-3}}{e^{1/x^2}}
Try l'Hopital twice on that instead, simplifying after each application.
Thanks! Is it possible to generalize that e^(-1/x^2)/x^n as n->0 (n>2 and an integer) also approaches 0?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
