Limit as n->infinity of (n^n)/n
  • Thread starter Thread starter Potatochip911
    Limit
The limit of n^n/n! as n approaches infinity is evaluated through various approaches, including the ratio test and comparisons with simpler functions. The ratio test leads to inconclusive results, prompting the exploration of bounding techniques and Stirling's approximation for more precise analysis. Participants discuss the relationship between n^n and n!, noting that n^n grows significantly faster than n! as n increases. A crude estimate shows that n^n/n! diverges, reinforcing the conclusion that the limit diverges to infinity. Overall, the discussion emphasizes the importance of understanding growth rates and estimation techniques in evaluating limits.
Potatochip911
Evaluate the limit ##\lim_{n\to\infty} \dfrac{n^n}{n!}##
Ratio test: ##a_{n+1}*\dfrac{1}{a_n}##
I was having trouble evaluating this so I tried to use the ratio test which unfortunately leads to ##\lim_{n\to\infty} \dfrac{n}{n+1}## which just ends up being 1 which does not tell me whether the series is convergent or divergent. Alternatively I tried looking at it like this but I couldn't see where to go from there $$\lim_{n\to\infty} \frac{n}{1} \frac {n}{2} \frac {n}{3} \cdots \frac{n}{n} $$
You can use either the last expression that you gave to bound the expression from below by a diverging function, or you can take the logarithm of everything and apply Stirling's approximation.
Sorry I'm quite lost as to how I would go about finding a boundary for this function, is there a theorem or something I should be aware of?
Hi potatochip911,
n^n/n! = (n*n*...n)/(1*2*...n)
(n+1)^(n+1)/(n+1)! = (n+1)(n+1).../(1*2*...(n+1)),
Hope this makes it easier, you can take out (n+1) from the second and compare the two series, and use induction, if the n^n/n! Is divergent then so is (n+1)^(n+1)/(n+1)!
How about n/k > 1 for n > k?
Noctisdark said:
Hi potatochip911,
I don't think I'm allowed to use induction to solve these problems.
Can I just do this? $$\frac{n^2}{2} < \frac{n^n}{n!} \mbox{on the interval} [1,\infty] \\ \lim_{n\to\infty} \frac{n^2}{2}=\infty$$ and then since a function smaller function diverges the original must also diverge? Edit: I think I messed this up again I keep thinking in terms of sums
You can even do this: ##n = n/1 < n^n/n!##
Potatochip911 said:
I don't think I'm allowed to use induction to solve these problems.Can I just do this? $$\frac{n^2}{2} < \frac{n^n}{n!} \mbox{on the interval} [1,\infty] \\ \lim_{n\to\infty} \frac{n^2}{2}=\infty$$ and then since a function smaller function diverges the original must also diverge? Edit: I think I messed this up again I keep thinking in terms of sums
You don't need induction, although it's perfectly valid to use induction for any maths problem - unless it's explicitly stated that you can't. Anyway, back to your problem. Where did you get ##n^2/2## from?
##n^n## and ##n!## both have ##n## terms; ##n^n## is clearly much larger than ##n!## as ##n## increases. So, all you need is a crude estimate. There is, in fact, a very simple estimate. Can you spot it?
PS: I see Orodruin beat me to it!
PPS: You are also allowed to calculate some values. For example, if you tried n = 5, you'd see that:
##5! = 120## whereas ##5^5 = 25 \times 125##
So, it should be fairly obvious from that where this sequence is heading!
PeroK said:
Where did you get n^2/2 from?
I would say he used the first two factors of:
rather than just the first.
Edit: Of course, this does not tell you how fast it diverges. Stirling's approximation will do that for you (and you should find that it diverges exponentially).
Okay I will keep that in mind for the future.
Yea its just I'm going through a textbook from start to finish and we haven't touched on induction yet so I didn't want to use it. Thanks for the help guys!
