Limit as x goes to infinity (algebraic)
  • Thread starter Thread starter mbisCool
    Infinity Limit
To find the limit as x approaches infinity for (x+2)/(sqrt(81x^2+15), dividing both the numerator and denominator by x simplifies the expression. This results in the limit transforming to (1 + 2/x)/(sqrt(81 + 15/x^2)). As x approaches infinity, the terms 2/x and 15/x^2 approach zero, leading to the limit being 1/sqrt(81), which equals 1/9. This method of dividing by the highest power is applicable to all rational polynomial limits as x approaches infinity.
mbisCool
limx->infinity (x+2)/(sqrt(81x^2+15))
The only thing i could think of doing was rationalizing the denominator to get (x+2)sqrt(81x^2+15) / 81X^2+15 however I am pretty sure this is the wrong route cause there doesn't seem to be anywhere to go from here.
Any help would be greatly apprciated :D the only problems i seem to ever have difficulty with are with roots in the numerator or denominator. any info in that regard would be of use as well.
divide top and bottom by x and write an x inside the root
what exactly do you mean by write an x inside the root. if i divide top and bottom by x i get ((x+2)/x) / ((sqrt(81x^2+15))/x). from here I am stuck again
alright its 1/9
note that this trick generalizes to all rational polynomial limits to infinity, just divide by the highest factor.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
