MHB Limit of integral challenge of (e^(-x)cosx)/(1/n+nx^2)
lfdahl
MHB
Find
\[\lim_{n\rightarrow \infty}\int_{0}^{\infty}\frac{e^{-x}\cos x}{\frac{1}{n}+nx^2}dx.\]
Mathematics news on Phys.org
Nice one.
My attempt:
Partial integration gives us:
\begin{aligned}\int\frac{e^{-x}\cos x}{\frac{1}{n}+nx^2}\,dx
&= \int e^{-x}\cos x\cdot \frac{n}{1+(nx)^2}\,dx \\
&= \int e^{-x}\cos x\,d\big(\arctan(nx)\big) \\
&= e^{-x}\cos x\arctan(nx) - \int\arctan(nx)\,d\big(e^{-x}\cos x\big)
\end{aligned}
Therefore:
\begin{aligned}\lim_{n\rightarrow \infty}\int_{0}^{\infty}\frac{e^{-x}\cos x}{\frac{1}{n}+nx^2}\,dx
&= \lim_{n\rightarrow \infty}\lim_{a\to 0^+,b\to\infty}\left[e^{-x}\cos x\arctan(nx)\Big|_a^b - \int_a^b\arctan(nx)\,d\big(e^{-x}\cos x\big)\right] \\
&= \lim_{n\rightarrow \infty}\lim_{a\to 0^+,b\to\infty}\left[ - \int_a^b\arctan(nx)\,d\big(e^{-x}\cos x\big)\right] \\
&= \lim_{a\to 0^+,b\to\infty}\left[ - \int_a^b\lim_{n\rightarrow \infty}\arctan(nx)\,d\big(e^{-x}\cos x\big)\right] \\
&= \lim_{a\to 0^+,b\to\infty}\left[ - \int_a^b\frac\pi 2\,d\big(e^{-x}\cos x\big)\right] \\
&= \lim_{a\to 0^+,b\to\infty}\left[ - \frac\pi 2\,e^{-x}\cos x\right]_a^b \\
&=\frac \pi 2
\end{aligned}
Klaas van Aarsen said:
Nice one.
My attempt:
\end{aligned}
Therefore:
&=\frac \pi 2
\end{aligned}
Thankyou, Klaas van Aarsen, for your participation and a correct answer! (Yes)An alternative solution:
\[I = \lim_{n \to \infty}\int_{0}^{\infty}\frac{e^{-x}\cos x}{\frac{1}{n}+nx^2}dx = \lim_{n \to \infty}\int_{0}^{\infty}\frac{e^{-x}\cos x}{1+n^2x^2}ndx = \lim_{n \to \infty}\int_{0}^{\infty}\frac{e^{-u/n}\cos (u/n)}{1+u^2}du\]
Since the functions $\frac{e^{-u/n}\cos (u/n)}{1+u^2}$ are boundedly convergent for all $u$ and $n$ between $0$ and infinity, we may use the Bounded Convergence Theorem to move the limit inside the integral giving
\[I =\int_{0}^{\infty}\frac{1}{1+u^2}du = \frac{\pi}{2}.\]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
