Limit of sin(3x)/π-x as x approaches π
  • Thread starter Thread starter Pithikos
    Limit
The limit of sin(3x)/(π-x) as x approaches π presents a challenge due to the indeterminate form. By substituting t = π - x, the limit can be rewritten as sin(3(π-t))/t, leading to further simplifications. The discussion highlights the application of standard limits, particularly sin(x)/x approaching 1, and the need for alternative methods since L'Hôpital's rule is not yet learned. Ultimately, the correct approach involves recognizing the relationship sin(3x) = sin(3π - 3x), which simplifies the limit to yield a final result of 3. The conversation also touches on the use of LaTeX for mathematical expressions.
Pithikos
lim of sin(3x)/π-x as x->π
I tryied replacing π-x with t so t=π-x and rewrote the whole limit as:
lim of sin(3(π-t))/t as t->0
that gives me(without the lim notation):
sin(3π-3t)/1 * 1/t
then I noticed that if I multiply the dominators and numerators with 3π-3t it doesn't help much because replacing t with 0 in (3π-3t) doesn't give 0 so therefore can't use the standard limit lim sinx/x -> 1 as x -> 0
I have been stuck with this problem 2-3 days now. I made some other mistakes in the first tries not worth mentioning. Now it seems I took the right way into the problem but I just feel stuck :/
Well, you should discriminate cases:
1) n=0, then you can use that sin(x)/x --> 1
2) n is not 0, then you will have to do something else... But in this case, we got a "number/0" situation, so this would give positive or negative infinity...
Since for x = pi => sin(3pi) = 0 and pi - pi = 0 one can apply I'Hopital's rule by differentiating the top and the bottom expressions.
Thing is that we haven't learned the L'Hopital's rule so for the exercise there must be some more "caveman" way to do this. We have only been working with standard limits like the following.
limits of x approaching 0 :
sinx/x -> 1
tanx/x -> 1
ln(1+x)/x -> 1
.. etc.
I think a previous poster thought the π symbol was the variable n.
First note that
\sin(3x) = \sin(3x - 3\pi) so
\frac{\sin(3x) }{\pi - x}=\frac{\sin(3x-3\pi) }{\pi - x}
Can you get it from there?
Thank you! Now I solved it :!)
Though instead of sin(3x-3π) I used sin(3π-3x) so it became:
sin(3π-3x)/3π-3x * 3/1 =
1 * 3
Btw with what tool do you write equations in that mathematical way?
1 * 3Btw with what tool do you write equations in that mathematical way?
Of course, you need a minus sign. The math is LaTeX using the tex tags. Click on an expression to see how it's written.
See https://www.physicsforums.com/misc/howtolatex.pdf
Actually, 3 is correct.
\sin(3x) = -\sin(3x - 3\pi) = \sin(3\pi - 3x)
This makes sense when you think about it: subtracting 3π is essentially the same as rotating the unit circle one half-turn (in either direction), so the sine function would have to change sign (pun not intended).
  • · Replies 21 ·
