MHB Limit (x1) as m->infinity ( x1 - the lowest root )
  • Thread starter Thread starter Vali
    Limit Root
The discussion revolves around finding the limit of the lowest root x1 of the quadratic equation x^2 - 2(m+1)x + 3m + 1 as m approaches infinity. The lowest root is identified as x1 = m + 1 - √(m^2 - m). To evaluate the limit, a suggested approach involves rewriting x1 as a fraction to simplify the expression. Participants clarify the notation and ensure understanding of the limit concept as m grows indefinitely. The conversation emphasizes the importance of correctly manipulating the equation to find the desired limit.
Vali
I have the following equation: x^2 - 2(m+1)x + 3m + 1=0
Also, I know that x1 is the lowest root of this equation.
I need to solve lim (x1) as m->infinity
A. 1
B. 3/2
C. 0
D. -1/2
E. -1
I tried to solve the equation with the discriminant then to calculate the limit but didn't work.
Also, I think that because x1 is the lowest root and the function graphic is a parabola, I tink that -b/2a (the peak of parabola) > x1 but I don't see how this condition would help me.
Some ideas?
Thanks!
Mathematics news on Phys.org
A. 1
B. 3/2
C. 0
D. -1/2
E. -1
Some ideas?
Thanks!
You did right to start by solving the equation, and you probably found that the lower root is $x_1 = m+1 - \sqrt{m^2-m}$. The trick now is to make that into a fraction, multiplying and dividing by $m+1 + \sqrt{m^2-m}$ to get $$x_1 = \frac{\bigl( m+1 - \sqrt{m^2-m}\bigr)\bigl( m+1 + \sqrt{m^2-m}\bigr)}{m+1 + \sqrt{m^2-m}}.$$ Can you take it from there, to get the limit as $m\to\infty$?
Yes, I replaced m with x because I usually work with x.
Thank you very much for your help :)
Hi Vali; do you mean "What number does x1 approach as m grows without bound"?
Yes.Sorry if I didn;t use the correct words.
Hey, no problem. The notation is unusual so I have asked for a clarification to benefit those who may not understand. Happy foruming! :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
