Limiting values of x for particle under force
  • Thread starter Thread starter MikeN
    Force Particle
The discussion revolves around determining the limiting values of x for a particle under a specific force described by F = -mω²(x - a⁴/x³). The particle starts at equilibrium position x = a with initial velocity v, and the conservation of energy principle is applied to find the maximum displacement. The derived equation for x shows similarities to the book's answer but initially lacks a crucial term. A mistake in transcribing the book's answer led to confusion, as the correct term involves a factor of 4 under the square root. The final expression for x aligns with the book's solution after correcting the transcription error.
MikeN
This problem is from Kibble and Berkshire's Classical mechanics (Fifth edition), Chapter 2, Question 20.
A particle of mass m moves in the region x > 0 under the force F = -m\omega^2\left(x-\frac{a^4}{x^3}\right) where \omega and a are constants. The particle is initially at the position of equilibrium (x=a) and is moving with a velocity v, find the limiting values of x in the subsequent motion.
F(x) = -m\omega^2\left(x-\frac{a^4}{x^3}\right)
V(x) = \frac{1}{2}m\omega^2\left(x^2+\frac{a^4}{x^2}\right)
From conservation of energy, \Delta K=-\Delta V
The initial kinetic energy is \frac{1}{2}mv^2, the particle is at the furthest point when the velocity is zero, therefore the final kinetic energy is zero. The initial potential is V(a) and the final is V(x).
0-\frac{1}{2}mv^2=-\left(\frac{1}{2}m\omega^2 \left(x^2+\frac{a^4}{x^2}\right)-m\omega^2 a^2\right)
The answer given in the book is:
x=\sqrt{a^2+\frac{v^2}{4\omega^2}}\pm\frac{v}{2\omega}
Plugging some values into this and comparing with my setup shows that I'm going wrong somewhere.
Solving my equation for x gives:
x^2=\frac{v^2}{2\omega^2}+a^2\pm\frac{v}{\omega}\sqrt{\frac{v^2}{4\omega^2}+a^2}
which is actually fairly similar to the answer in the book after it's squared, except my answer is missing a term (\frac{v^2}{4\omega^2}) but I can't see where this comes from.
More similar than you realize, it seems.
Likes MikeN
Haha, I feel silly now. When I copied the answer from the book down onto paper I had a 2 inside of the square root instead of the 4. Thank you!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
