Line of charge and conducting sphere (method of images)
thedddmer
Need to use method find the geometrical place of the images and the charge density of an infinite line of charge and a conducting sphere
so the problem is only to find a segment of the line of charge inside the sphere, should be and kind of egg shape image (at least is what someone told me)
I was thinking of using the sphere and point charge as an analog, but is quite diferent from what i have seen
OK
An infinitesimal element of the line charge can be treated as a point charge. Sketch a diagram of the situation and consider an arbitrary element of the line charge.
https://en.wikipedia.org/wiki/Circles_of_Apollonius
The alternative definition of a circle: the set of all points whose ratio of distances from two points is a fixed constant.
After all the potential of two (equal but opposite line charges) is
##\frac{\lambda}{2 \pi \epsilon_0} \ln \frac{r_1}{r_2}##
If that is a constant
then
##\frac{r_1}{r_2}## is also constant
I'm having a hard time relating this to the infinite line charge and conducting sphere. I do find that the image curve is a circle.
But I haven't yet figured out how Apollonius' definition of a circle helps in this problem.
Oh wow I totally misread the OP. I thought OP wanted to know the image of an infinite line charge inside a cylinder. And wanted to use the point charge image inside a sphere as an analog.
Welp.
