Linear Algebra: A Basis for a Finite Dim VS
In summary, a basis is a set of vectors that spans all the space. If you are given a dimension for a vector space, then by the replacement theorem, any linearly independent subset of V that's of size n will form a basis for V...if it has a basis consisting of a finite number of vectors. In this case n vectors. However, it is not enough to simply show that the set is linearly independent.
Bachelier
376
Why is it enough to prove that a set of vectors is a BASIS to a FINITE DIMENSIONAL Vector Space, it is enough to show that it is Linearly Independent.
No Need to prove that it spans the whole vector space?
Hint: What is the definition of finite-dimensional? A vector space is n-dimensional, if...
This is my point, we still have to show that the number of elements in the set is equal to the dimension of the vector space V. For instance if the dim is unknown, then we must show the set spans. Otherwise using just the fact that V is finite dimensional is not enough.
Am I reading this correctly?
Thank you.
A basis is a set of linearly independent vectors that span all the space. The first important theorem tells us that if one basis is finite then any other basis is also finite and they have the same number of vectors. This common number is then called the dimension of the space.
a basis is any set of linearly independent vectors that span a space V.
If you are given a dimension for a vector space V, then by the replacement theorem , any linearly independent subset of V that's of size n will form a basis for V
OK, with that definition things get circular. The one I had in mind is that dim V=n if there exists a linearly independent subset of V with n members but no linearly independent subset of V with n+1 members. Suppose that dim V=n, and that B is a linearly independent subset of V with n members. Let x be an arbitrary member of V. If x is in B, then x is obviously a linear combination of the members of B. If x is in V-B, then [itex]B\cup\{x\}[/itex] is linearly dependent (since it has n+1 members), so x is a linear combination of the members of B in this case too.
Perhaps I am reading the opening post different than you guys, but my answer: it is NOT enough, since otherwise any linearly independent set - whether or not it is maximal - would be a basis.
The set
[tex]\{(1,0,0),(0,1,0)\}\subset\mathbb{R}^3[/tex]
is linearly independent, but not a basis.
The set
[tex]\{(1,0,0),(0,1,0),(0,0,1)\}\subset\mathbb{R}^3[/tex]
is also linearly independent, but moreover it spans R^3, hence it is a basis.
Of course, if you know the dimension of the vector space, say n, then in order to prove that some set consisting of precisely n vectors is a basis, it IS enough only to show linear independence. But that was not included in the question.
The OP should have said "a set of n vectors" and "an n-dimensional vector space" instead of "a set of vectors" and "a finite dimensional vector space". I sort of assumed that that's what he meant, and then quickly forgot that he actually said something else.
I thought the question was pretty straight-forward by itself and needs no clarification.. And yes, I agree with Landau and his counterexample. It simply isn't enough.
Great answers everbody. Thank you very much.
FAQ: Linear Algebra: A Basis for a Finite Dim VS
What is linear algebra?
Linear algebra is a branch of mathematics that deals with the study of linear equations and their representations through matrices and vector spaces. It involves solving systems of linear equations, finding eigenvalues and eigenvectors, and performing operations on matrices and vectors.
How is linear algebra used in real life?
Linear algebra has various applications in fields such as physics, engineering, computer science, and economics. It is used to solve problems involving systems of equations, image and signal processing, and data analysis. It also plays a crucial role in creating 3D computer graphics and machine learning algorithms.
What is a basis in linear algebra?
A basis in linear algebra is a set of linearly independent vectors that can be used to represent any vector in a vector space. It is the smallest set of vectors that can span the entire space and can be used to form any other vector in the space through linear combinations.
What is the difference between a finite and infinite dimension in linear algebra?
In linear algebra, the dimension of a vector space refers to the number of linearly independent vectors needed to span the space. A finite-dimensional space has a finite number of dimensions, while an infinite-dimensional space has an infinite number of dimensions. Finite-dimensional spaces are easier to visualize and work with, while infinite-dimensional spaces are often more abstract and require more advanced techniques to study.
What is the importance of linear algebra in machine learning?
Linear algebra is essential in machine learning as it provides the necessary tools for data manipulation, transformation, and analysis. Many machine learning algorithms use linear algebra operations, such as matrix multiplication and vector operations, to process and represent data. It also provides a mathematical foundation for understanding and developing more advanced machine learning techniques.
