Linear applications simple doubt
In summary, the Fredholm alternative states that for linear maps between finite-dimensional spaces, an injective endomorphism is automatically bijective. This is not always true for infinite-dimensional cases, where the rank-nullity theorem cannot be used.
TrickyDicky
3,507
28
Is an injective endomorfism automatically bijective?
R136a1 said:
If you are talking about linear maps between finite-dimensional spaces, then yes. This is known as the Fredholm alternative: http://en.wikipedia.org/wiki/Fredholm_alternative
Thanks for confirming that intuition and for the pointer to Fredholm alternative, never heard of it.
Doesn't this follow from rank-nullity theorem?
for finitely generated modules over other rings this can fail, e.g. if Z is the integers, the injective endomorphism Z-->Z taking n to 3n is injective but not surjective. Interestingly however, a surjective endomorphism of a finitely generated module is always injective as well.
Yes. But the Fredholm alternative also hold in some infinite-dimensional cases. There, you can't use rank-nullity.
FAQ: Linear applications simple doubt
What is a linear application?
A linear application is a mathematical function that maps one or more input values to an output value using a linear relationship. This means that the output value can be calculated by multiplying the input values by a constant number and adding them together. In other words, the output value is a linear combination of the input values.
2. What are some real-life examples of linear applications?
Linear applications can be found in many real-life situations, such as calculating the cost of a grocery bill based on the price per item and quantity purchased, determining the distance traveled based on speed and time, or predicting the growth of a population over time. They can also be used in engineering, economics, and other fields to model relationships between variables.
3. How can I identify if a problem involves a linear application?
A problem involving a linear application will typically provide you with a set of input values and ask you to calculate an output value using a linear relationship. You can also look for key words such as "directly proportional" or "constant rate" in the problem statement, which indicate a linear relationship.
4. What is the difference between a linear application and a linear equation?
A linear application is a function that uses a linear relationship to map input values to output values. A linear equation, on the other hand, is a mathematical statement that equates two expressions using only variables to the first power and constants. In other words, a linear application is a type of function, while a linear equation is a type of algebraic statement.
5. How can I solve a linear application problem?
To solve a linear application problem, you will need to first identify the input values and the linear relationship between them and the output value. Then, you can use the formula for a linear function (y = mx + b) to plug in the input values and solve for the output value. It is also important to check your answer by plugging it back into the original problem and making sure it makes sense in the given context.
