MHB Linear Equations - Cost per Pound of Coffee Beans
The discussion revolves around solving a system of linear equations to determine the cost per pound of espresso and vanilla flavored coffee beans based on two mixtures. The equations derived from the mixtures are 18E + 17V = 306.50 and 19E + 15V = 298.50. Participants suggest using either substitution or elimination methods to solve for the unknowns E (espresso) and V (vanilla). One method involves isolating V in the first equation and substituting it into the second, while another approach suggests manipulating the equations to eliminate V directly. Ultimately, both methods lead to finding the values for E and V, providing a solution to the cost per pound of each coffee type.
AROJ
My problem is:
A coffee house blended 18 pounds of espresso flavored coffee beans with 17 pounds of vanilla flavored coffee beans. The 35 pound mixture cost \$306.50. A second mixture included 19 pounds of espresso flavored coffee beans and 15 pounds of vanilla flavored coffee beans. The 34 pound mixture cost \$298.50. Find the cost per pound of the espresso and vanilla flavored coffee beans
So I know,
18E+17V=306.50
19E+15V=298.50
What next?
Mathematics news on Phys.org
AROJ said:
My problem is:
So I know,
18E+17V=306.50 ... (1)
19E+15V=298.50 ... (2)
What next?
where (1) and (2) are the equations in question
You have two equations and two unknowns so you can solve using simultaneous equations. You can either do this by elimination or substitution. In this case I would use the latter. To do this make E or V the subject of an equation and substitute it's value for E or V in the other equation. In this case...
$$18E + 17V = 306.50 $$
$$V = \dfrac{306.50-18E}{17}$$
You can now sub $$ \dfrac{306.50-18E}{17}$$ for V in (2)
$$19E + 15 \left(\dfrac{306.50-18E}{17}\right) = 298.50$$
This gives an equation in E only which means you can find E and hence V
I did a few things here...I put a backslash in front of the dollar signs to that they would not be parsed as $\LaTeX$ tags, I edited your first equation so that the leading coefficient is 18, and I moved your post to its own thread. We prefer that new questions be posted in their own thread. This is less confusing and ensures that you get prompt help.
I see you have already gotten help with the problem, so I will leave you in the expert hands of SuperSonic4. :D
Another way: starting from the equations
18E+ 17V= 306.50
19E+ 15V= 298.50
Multiply the first equation by 15 (the coefficient of V in the second equation) and multiply the second equation by 17 (the coefficient of V in the first equation) to get
270E+ 255V= 4597.5
323E+ 255V= 5074.5
Now, the two equations have the same coefficient for V and subtracting the first equation from the second eliminates V: 53E= 477 so that E= 477/53. Now put that back into either of the original equations to get a single equation for V.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
