Linear speed of sphere as it passes through lowest point
The discussion centers on calculating the linear speed of a sphere as it passes through the lowest point, using specific mass values and the length of a rod. The work done by gravity is expressed in relation to the masses and the gravitational constant, leading to a derived final angular speed of 3.656 rad/s and a linear speed of 1.46 m/s. There is confusion regarding the treatment of torque, with the contributor questioning whether the torque should be considered zero or if another quantity is miscalculated. It is clarified that the work done by gravity equates to the work done by torque, emphasizing that it should not be counted twice. The contributor acknowledges their initial uncertainty about the calculations.
dl447342
A slender rod is 0.8 m long and has mass 0.12 kg. A small 0.02 kg sphere is welded to one end of the rod, and a small 0.05 kg sphere is welded to the other end. The rod, pivoting about a stationary, frictionless axis at its center, is held horizontal and released from rest. What is the linear speed of the 0.05 kg sphere as it passes through its lowest point?
Moment of inertia of slender rod of mass M and length L: ##\frac{1}{12} ML^2##, work done by constant torque through an angular displacement ##\Delta \theta = \tau \Delta\theta##, work-kinetic energy theorem, work done by gravity when an object of mass m falls a vertical distance h is ##mg h##. Kinetic energy = ##\frac{1}2 I \omega^2##.
Let ##m_s = 0.05, m_{s_1} = 0.02, m_r = 0.12, L = 0.8.## be the masses of the two spheres, mass of the rod, and length of the rod. Then the work done by gravity when the rod reaches the vertical position is ##(m_s(L/2) - m_{s_2}(L/2))g## and the kinetic energy equals ##\frac{1}2 (\frac{1}{12} m_rL^2 + \frac{L^2}4 (m_s+m_{s_2}))(\omega_f^2)##, where ##\omega_f## is the final angular speed. If I treat the work done by torque as zero, then I get the correct answer of ##\omega_f = 3.656 rad/s\Rightarrow v_f = 1.46 m/s##, but I thought the work done by torque should be ##\frac{L(m_s-m_{s_2})}2\cdot 9.8##. Why would the torque be zero or is some other quantity different from what I calculated?
Realize that gravity provides the torque on this system. So the work done by gravity is the work done by the torque. Don't count it twice.
Thanks. I was thinking I was counting something twice.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
10K
