Linear Transformations Rn->Rm Question
The discussion focuses on understanding the linear transformation T: Rn to Rm defined by T(x, y) = (2x, y). Participants seek clarification on the notation used in the solution manual, specifically the introduction of variables x1, y1, x2, and y2. The transformation is validated using the linearity conditions, particularly T(u + v) = T(u) + T(v). However, it is noted that the proof is incomplete as it omits the second condition, T(cu) = cT(u). The conversation emphasizes the importance of both conditions in proving linearity.
haribol
Linear Transformations Rn-->Rm Question
I would be very grateful if someone can explain what is going on in the following problem:
Determine whether the following T:Rn to Rm
T(x,y)=(2x,y)
Solution from solutions manual:
T((x1,y1) + (x2,y2)) = (2(x1+x2), y1+y2) = (2x1,y1) + (2x2,y2) = T(x1,y1) + T(x2,y2)
My questions are
1. Where did the x1's and the x2's and the y1's and the y2's come from?
2. Can you please explain what's happening step by step?
[PS]--> The questions asks to use the theorem which states:
A transformation T:Rn --> Rm is linear if and only if the following relationships hold for all vectors u and v in Rn and every scalar c
a) T(u+v) = T(u) + T(v)
b)T(cu) = cT(u)
T(x,y)=(2x,y)
My questions are
b)T(cu) = cT(u)
He has set \vec{u} = (x_1,y_1), \ \ \vec{v} = (x_2,y_2) and showed using vector addition properties that T(\vec{u}+\vec{v}) = T(\vec{u})+T(\vec{v})
This proof is imcomplete though because he left out condition b).
Thank you quasar987 for the clarification. The manual does include the proof using condition b) but I forgot to type it.
Thanks for that clarification.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
