Listing symmetries geometrically and analytically, what do I do?
  • Thread starter Thread starter JohnMcBetty
    Symmetries
JohnMcBetty
I have found this question and not sure where to begin in terms of solving it. PLEASE HELP!
Consider a double square pyramid . Introduce a coordinate P system so that the
vertices of P are:
A=(2,0,0)
B=(0,2,0)
C=(-2,0,0)
D=(0,-2,0)
E=(0,0,1)
F=(0,0,-1)
List the symmetries of P. Do this both geometrically and analytically.
hint number 1: E and F are closer to the origin than the other vertices. so they either remain fixed by a symmetry, or swapped.
hint number 2: by hint number 1, all symmetries act on A,B,C and D entirely in the xy-plane. A,B,C and D form a square.
Thanks Deveno!
Ok so far this is what I have.
If we rotate the plane containing A,B,C,D
Rotation 1, 90 degrees = A maps to B maps to C maps to D maps back to A
Rotation 2, 180 degrees = A maps to C back to A again, and B maps to D and back to B.
Rotation 3, 270 degrees = A maps to D maps to C maps to B maps back to A
Rotation 4 would just be our initial point (epsilon)
Reflection 1, through plane containing E and F, A maps to D and back to A. B maps to C and back again.
Reflection 2, through the plane containing A,B,C, and D, E maps to F and maps back to E.
I would then compose all of the rotations with all reflections
Would this be all I would have to do? Better question, did I solve this problem in a correct manner?
Thanks Deveno!
E and F don't determine a plane, they are only two points.
you can regard these symmetries as a subgroup of S2 x S4, since the reflection through the xy-plane doesn't change A,B,C or D, and the rotations in the xy-plane and the reflections in the xy-plane don't change E or F (that is, swapping E and F commutes with all operations that only affect the xy-plane).
i count 16 distinct symmetries in all (the subgroup corresponding to the subgroup of S4 isn't all that big, we can't allow "twisted" mappings of vertices).
So should I just say that reflection 1 is a reflection through the origin?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
