Local mechanism for nonlocal anticorrelations inside spin theory
iste
56
TL;DR Summary
Recent theory of spin implies localized elliptical polarization in fields. In field media with an underlying microscopic particle theory available, this is mediated by the elliptical orbit of classical particles. It then seems logically possible - and easily visualizable - for those particles to evince nonlocal correlations (albeit not all aspects of photon polarization correlations) given that they share the same fundamental description. Importantly, this mechanism is entirely local.
Spin (and therefore photon circular polarization) can be constructed generically in terms of intrinsic rotations on vector fields, whether describing classical and quantum physical systems: e.g.
https://scholar.google.co.uk/scholar?cluster=14889979702374754652&hl=en&as_sdt=0,5
Building on this kind of construction, a relatively recent model ascribes the cause of spin to elliptical polarization localized to individual points within those fields. This elliptical polarization is proportional to the local spin density that is integrated over the field to get the total spin: e.g.
https://scholar.google.co.uk/scholar?cluster=15022687356306265602&hl=en&as_sdt=0,5&as_vis=1
(sections 5 & 6)
The kinds of rotational motion implied by this localized polarization are experimentally observable. It also resolves a paradox regarding the spin of plane waves, and explains the enigmatic "virtual" properties of spin that distinguish it from orbital angular momentum (i.e. how there is spin current without probability density transport). Due to how the construction of spin is so generic, this localized polarization has been formulated for a number of systems such as electromagnetic waves, water, acoustic waves, electron plasma and the electron quantum state (spinning probability current). It then implies localized elliptical orbits of particles whenever such a microscopic theory is available; for water, the predicted trajectories have been observed via probe particles (depiction in paper below).
https://scholar.google.co.uk/scholar?cluster=5115823896615614796&hl=en&as_sdt=0,5&as_vis=1
https://scholar.google.co.uk/scholar?cluster=2602243500647624252&hl=en&as_sdt=0,5&as_vis=1
https://scholar.google.co.uk/scholar?cluster=17892291218685033829&hl=en&as_sdt=0,5&as_vis=1
Importantly, the local elliptical polarization possesses the same properties as any classical or quantum descriptions of photon / light polarization, regardless of what medium is being described. For instance, local circular polarization at a point in space can be described in terms of two interfering orthogonal components that are ±90° phase-shifted, instantiable by circular orbits of particles. If we then additionally have a ±90° phase shift between the rotations of two separate particles, they would clearly display similar kinds of anti-correlations as entangled photons in virtue of the periodicity of their respective orbits. When one particle is experiencing the vertical part of its motion, it would imply that the other particle is in the midst of a horizontal part and vice versa (or when comparing any other two perpendicular pairs of directions). You could fix the phase relation at some initial source and then this correlation could be maintained without communication so long as the two particles keep orbiting in the same way undisturbed, even if they travel very far apart. Because of the continual orbiting, any measurement of particle direction would obviously not be pre-defined at source despite the anti-correlations. This then suggests that it is at least logically possible for nonlocal correlations of classical particles to be mediated by a mechanism that is entirely local. The particles don't even need to have locally interacted so long as the appropriate phase relation can be set.
In a paper by Jung:
https://www.frontiersin.org/journals/physics/articles/10.3389/fphy.2020.00170/full
They derive polarization correlations entirely in classical optics from a phase shift for circularly polarized light + Malus Law. From this, it seems that, though the orbital motions of particles obviously could not explain superposition or probabilistic aspects of measurement which would be connected to the local Malus Law aspect, this mechanism does seem to be able to account for the entire non-local aspect of these correlations.
Obviously, the description that has been given of polarization correlations with orbiting particles is nowhere near laying out some kind of full model of photon polarization correlations but it suggests the logical possibility of mediating non-local correlations via a local mechanism. I think the most interesting application for this would be to fit it into an existing interpretation / formulation such as stochastic mechanics. Markovian stochastic mechanics can reproduce all quantum predictions through classical microscopic particles moving randomly on continuous trajectories. The theory is overtly non-local, not so dissimilarly to Bohmian mechanics. However, it has been shown before that this non-locality disappears if you use non-Markovian diffusions, first by Edward Nelson in his book Quantum Fluctuations, and then in Levy and Krener's reformulation of stochastic mechanics using reciprocal diffusions:
https://web.math.princeton.edu/~nelson/papers.html
https://www.google.com/search?q=Stochastic+mechanics+of+reciprocal+diffusions+pdf
Levy and Krener's analysis identifies the cause of non-locality in stochastic mechanics with the inability for Markovian diffusions to satisfy the Schrodinger evolution without corrections to their potentials, something not required in the non-Markovian subclass they constructed (dubbed "Quantum diffusions"). The Markovian assumption may plausibly be an artificial idealization with non-locality as a byproduct that is ultimately not veridical. A possible local mechanism for photon correlations then gives further reason to take this idea seriously. Stochastic mechanics may take care of the rest of the limitations of the mechanism. The stochasticity may take care of the Malus Law aspect of correlations unaccounted for in this mechanism (e.g. non-commutativity / uncertainty relations can be derived from stochastic trajectories) and the non-dissipative, conservative nature of the diffusion accounting for maintaining the periodic orbits similar to how circularly rotating light can just keep on rotating.
Edit:
Its also interesting to note that the recent explicitly non-Markovian stochastic formulation of quantum theory by Barandes (subject of a post some time ago) explains non-local entanglement through the ability of the non-Markovian transition matrix to remember correlations from local interactions in the past (and implying that a Markovian counterpart could not do this). This explanation actually seems quite reminiscent of the idea that a phase shift is set at source and maintained or remembered over time until measured / decohered.
iste said:
Obviously, the description that has been given of polarization correlations with orbiting particles is nowhere near laying out some kind of full model of photon polarization correlations but it suggests the logical possibility of mediating non-local correlations via a local mechanism. …
The Jung paper includes a fantastic list of references on various tests of entanglement and closing of loopholes. However, there is a huge hole in the discussion of local explanations of quantum nonlocality. Specifically: experimental entanglement of systems that have never interacted or existed in a common light cone, including delayed choice versions.
https://arxiv.org/abs/0809.3991
This experiment (and many others like it) completely invalidates your hypothesis (of a local explanation). Which is why it is missing as a reference, I guess.
In my reference, an entangled photon pair is created that have never been close to each other. The choice to entangle them or not is freely decided and executed by a remote experimenter. There is no local interaction to tie the entangled photons to each other.
I really miss the point of the attempts being made to re-introduce classical locality into QM when there are well-accepted counter examples from nearly 20 years ago. An author putting forth such hypothesis must start with the most difficult challenge, not an easier one. And this has not been done.
Likes weirdoguy, PeterDonis and msumm21
It doesn't matter whether they ever contacted. If you look at the pair of graphics of rotating waves in this wikipedia section on Handedness conventions:
https://en.wikipedia.org/wiki/Circular_polarization#Handedness_conventions
I am pretty sure the little arrows on both graphics are rotating at a constant rate in a way that when one is pointing in a certain direction the other is always pointed in another direction, displaying a phase shift. That is the kind of correlation. Clearly they don't need to communicate to be in-synch and there is no reason why they need to be in physical contact for different people to independently calibrate the rotation of either of the little hands so that they both are in-synch. It simply doesn't matter if the pair were ever in local contact if you can set the correct phase relation somehow. Regarding the delayed choice? No entanglement experiments, with or without delay, will work unless the phase shift and coherence is preserved throughout the whole experiment, something which it seems experimentalists take great care in trying to achieve in their set ups to avoid the destruction of the entanglement; messing about with the paths in interferometers can affect the phase, for instance, as you would expect. So such delayed entanglements would still imply that the phase relation, the synchronized nature of orbits or rotations is still totally preserved. Once this has been set in a way that it is preserved in the set up, any kind of delay in the measurements doesn't matter in principle. The correlation is fully accounted for by the phase regardless of which photon gets measured first or the time between their measurement because the experiment has been set up in a way that their synchronization (e.g. of the little hands in the graphics of the rotating waves above) up to measurement has been pre-set without needing to invoke spooky collapse.
In my cited experiment, they are created fully independently and distant from each other. So none of what you mention applies. They are not correlated in any way to begin with. It takes a remote action to cause them to become entangled. If that action does not occur, they are not entangled. And every piece of the process is distant and nonlocal.
It seems that there two things people try to do when they cannot accept the validity of Bell's theorem. One is to look for some local mechanism, a local interaction that will explain the results. This of course is stupid because the theorem says that it is impossible. The second is to try to find some nonlocal mechanism, some kind of action at a distance. This is also stupid. It is an attempt to find a classical explanation. QM is the explanation and needs nothing more, unless you cannot accept QM and desperately cling to classical worldview.
Likes pines-demon, PeroK and weirdoguy
So you say that it is stupid to ask whether predictions of QM can be explained by a classical worldview. But Bell obtained his theorem precisely by asking such a question. So are you telling that the Bell theorem has been obtained by asking a stupid question, and yet that the theorem itself is not stupid?
No, I said that it is stupid to look for such an explanation. You can ask the question if there is such an explanation.
No again. I didn't say that it is a stupid question to ask if such an explanation exists. I said that it is stupid to look for such an explanation. In view of the theorem it is even more stupid to try that.
martinbn said:
The second is to try to find some nonlocal mechanism, some kind of action at a distance. This is also stupid. It is an attempt to find a classical explanation. .
I wouldn’t call a nonlocal mechanism “classical”. And considering the number of experiments that demonstrate some form of quantum nonlocality (probably over 1000), that seems like a good place to look.
By classical I meant non quantum.
They demonstrate nonlocality in the sense of violating Bell's inequality, not in the sense of action at a distance. They couldn't demonstrate action at a distance because QM has no such action but predicts all the experiments so far.
So are you saying that such an explanation of QM, with a classical worldview, does not exist? Isn't Bohmian mechanics a counterexample?
Likes physika
Not by the definition of "classical" that @martinbn is using per post #10, which explicitly rules out Bohmian mechanics as "classical" since it is a quantum theory. :wink:
Well, I didn't say that such an explanation doesn't exist. Only that it is not a good idea to look for such explanations.
And why is it not a good idea?
That's obvious.
  • Skeptical
Likes physika and Demystifier
Of course there is explicit nonlocality in QM. The quantum expectation value of measurements on entangled systems is dependent on the nature of distant measurements, and nothing else. For example: for spin/polarization, it is the difference between 2 distant angle settings (usually called theta) made independently. That is straight out (quantum) nonlocality.
Yes, of course, and this is not in any way contrary to what i said.
No, the correlations are dependent on the nature of distant measurements. But the expectation values of individual measurements taken in isolation are not. If Alice and Bob each measure an entangled qubit, Bob's expectation value for a given measurement (i.e., a given angle he chooses for his measuring device to measure the spin of the qubit), taken in isolation, i.e., without any knowledge of Alice's measurement, is the same regardless of what measurement Alice chooses to make on her qubit. The entanglement only shows up in the correlations between the two measurements when the results from both are analyzed together.
Seriously, you are simply mincing words.
The quantum expectation value OF THE CORRELATIONS is strictly dependent on distant settings. There is no classical situation where this is true. Of course there is no distance involved in a single measurement.
Was your comment really necessary?
So you agree with me? "There is no classical situation where that is true."
Any mainstream interpretation that accounts for conventional EPRB experiments with local interactions can account for the creation of entanglement between photons that have never been close to each other with local interactions.
No, there are no such explanations I have ever seen or heard of - and I’ve seen a lot. What there are a lot of are *claims* of such, and usually they focus on demonstrating equivalence to QM mathematically. A full remote swapping context features 2 separated measurements (violating a Bell inequality) and a third remote spot where a decision can be made (with the free will of the experimenter) to create entanglement or not.
Anyone who can pitch that as local action successfully would be of great interest to me. Just show me a paper with a diagram. :)
Which is not what the post I was responding to said. The claim that post made said "measurements", which is much more general than "correlations". That's why I clarified it.
What do you mean by "local interactions"? Depending on how you interpret that phrase, it could apply to all interpretations, or none.
True, but I think the time-synchronization required for the independent sources is kind of analogous in that it is required to obtain the new entanglement state through coherence.
As said before, this mechanism in original post doesn't account for all aspects of photon polarization correlation but it seems to me it can produce correlations analogous to entanglement swapping.
For two "entanglements" of orbiting particle pairs (e.g. photons 1 & 2 vs. photons 3 & 4), there could be initially no overall correlation between the pairings when you consider that the outcomes in photons 1 & 2 are independently random from those of photons 3 & 4 so that all possible pairs of outcomes for 2 & 3 (or 1 & 4 respectively) are possible.
But when you consider coincidence detection or measurement at 2 & 3 and condition on the outcomes, then it seems natural that the photons 1 & 4 must be correlated because if 3 is always precisely correlated to 4 and 1 is always precisely correlated to 2, then a definite relationship between 2 & 3 by measurement is clearly enough to establish a definite relationship between 1 & 4. This relationship would go away when you consider all of the possible outcomes at the same time, but statistical conditioning (which afaik is all that projective collapse implies on a formal level) unveils the underlying correlations which would show entanglements in 1 & 4.
This is a similar kind of description as the "entanglement through measurement" section suggests here:
https://scholar.google.co.uk/scholar?cluster=17666541244192212757&hl=en&as_sdt=0,5&as_vis=1
I think this would seem to suggest that what is strange about entanglement swapping is nothing above what is strange about conventional entanglement.
Likes Fra
Such a mechanism wouldn't contradict Bell's theorem because it isn't saying outcomes are determined from the source, nonetheless the correlation is determined from source and kind of 'remembered' by both particles so it wouldn't require spooky communication. It would still be non-local in the Bell sense; I mean't spooky action at a distance.
There is an interesting example of a kind of memory of correlations in a model of a classical hydrodynamic system here:
https://journals.aps.org/prfluids/abstract/10.1103/PhysRevFluids.7.093604
Because the fluid bath exhibits non-Markovian behavior, droplets surfing on the bath continue to remember correlations between themselves even though a physical barrier has been put up that prevents them from communicating in any way at all. Sort of like entanglement.
Also I might add that a model of quantum mechanics does exist that is constructed purely from classical (but stochastic) assumptions and can in principle reproduce all of the behaviors of quantum mechanics (like Bohmian mechanics can). It is maybe just not very well known:
https://en.wikipedia.org/wiki/Stochastic_quantum_mechanics
Yes, proposing such a mechanism would contradict Bell's theorem, since it is precisely the kind of mechanism that Bell's theorem applies to. What you call "determined from source and kind of 'remembered' by both particles" is what is called "hidden variables" in Bell's theorem.
Classical models are irrelevant here, since no such model can produce correlations that violate the Bell inequalities.
No, it isn't. The fact that "stochastic quantization" is given as one of the assumptions in the Wikipedia article you reference should be a huge red flag to you that your claim here is not valid.
I'm not defending those particular papers but...
There is a third option: Accept Bell's theorem as such, but that claims it's premises are not valid in the situation, because one seeks not a local mechanism for explaning the results, but just to explain the correlation.
Bell's theorem proves that no explanation of the correlation that builds on "hidden values" will work, but it does not reject a theory that may have a mechanism, but only correlations of unknown values are required. I think this type of explanation need not be (or probably even can't be) "classical".
QM, describes it but the I think the idea that there is no way to improve the understandin and causal mechanism of QM, without cling onto an outdated worldview, is something I do not share.
QM is the best theory we have, but that doesn't mean it has nothing left to wish for.
/Fredrik
Likes physika
  • #31
Do you have any references for these claims? Please bear in mind that, even in this forum, personal speculation is not permitted.
  • #32
The memory thing isn't a hidden variable like that because it is the correlation that is determined from source and remembered, not the outcomes. The mechanism also already exists in quantum experiment and formalism in the sense that all that is being talked about is a phase shift. You can see in the Jung paper of original post that the phase that determines the correlation from source is something they have gotten from previous influential papers. You can find an interferometric version of this phase in papers by Horne et al. from late 80s/early 90s. Dr. Chinese posted an entanglement paper in a circular polarization thread not long ago that also mentions the phase at source and how changing it can change from vv hh correlations to vh hv correlations. The issue is physically interpretating some mechanism that already exists in quantum mechanics rather than adding some distinctly novel mechanism that may or may not reproduce the correct behavior - so I don't think it would contradict Bell.
Well the same type of classical hydrodynamic system as the last paper has been shown to be able to violate Bell inequalities in the case where there is no barrier. The authors are I believe looking at the barrier case so that is an open question I think.
https://scholar.google.co.uk/scholar?cluster=9229154603514546961&hl=en&as_sdt=0,5&as_vis=1
I think this is a case of two different things with the same name. The assumptions in stochastic mechanics come from what you would ordinarily think of as classical stochastic process.
  • #33
But when you consider coincidence detection or measurement at 2 & 3 and condition on the outcomes, then it seems natural that the photons 1 & 4 must be correlated because…
What you are suggesting cannot be true, and the papers themselves say the same thing: there are no correlations between 1 & 4 unless and until the decision is made to execute a swap. Let me know if you need a quote/reference on that. Monogamy of Entanglement prevents that, for one thing.
But you are missing a critical point in your use of the word “correlations”. They are *perfect* correlations, which are only possible with entangled systems. On the other hand, in a coherent laser beam, photons are correlated but only have the same polarization at 4 angles. Big difference, right! There cannot be any deeper correlation even between photons from the same source, and certainly not from independent (but phase-locked) sources.
And the most important element is yet again bypassed: The perfect correlations only appear if the decision to execute the swap is made. This is dependent on whether the 2 & 3 photons are indistinguishable (leading to entanglement) or not. That decision and its execution occur remotely. Where is the local mechanism to address this?
As I say: claims of a local mechanism to explain entanglement are often made, but application to modern swapping experiments is sadly lacking. (Hand-waving does not count in light of experimental evidence to the contrary.)
Likes PeroK
  • #34
There is no "mechanism" in QM. That's why there is not one single generally accepted interpretation of QM. People can "explain" a given QM result with different interpretations that use completely different, inconsistent, and incompatible "mechanisms".
Likes Fra and PeroK
  • #35
Well, what I mean by 'mechanism' is just something in quantum mechanics regardless of quantum mechanics.
