MHB Locating Points for Vector Field $F$: $F_x=0$, $F_y=0$, and $|F_x|=1$
The discussion focuses on determining specific loci for the vector field \( F=2(x+y)\sin\pi za_x-(x^2+y)a_y+\left(\frac{10}{x^2+y^2}\right)a_z \). For the condition \( F_x=0 \), it is concluded that \( z \) must be an integer and \( x \) must equal zero. There are no points where \( F_y=0 \) since the coefficient of \( a_y \) is always non-zero. The equation for \( |F_x|=1 \) results in a complex expression involving \( x \), \( y \), and \( z \). Further simplification of this equation remains uncertain, indicating the need for additional insights.
paulmdrdo1
Given Vector Field: $F=2(x+y)\sin\pi za_x-(x^2+y)a_y+\left(\frac{10}{x^2+y^2}\right)a_z$ specify the locus of all points at which a.) $F_x=0$ b.) $F_y=0$ c.) $|F_x|=1$
please help me get started with this. thanks!
Mathematics news on Phys.org
Hi paulmdrdo, :)
I am assuming that \(a_x,\,a_y\mbox{ and }a_z\) stands for basis vectors of some coordinate system. For (a), take the partial derivative of $F$ with respect to $x$. You will get,
\[2\sin(\pi z)a_x-2xa_y-\frac{20x}{(x^2+y^2)^2}a_z=0\]
\[\Rightarrow z\in \mathbb{Z} \mbox{ and }x = 0\]
For (b) notice that the coefficient of \(a_y\) is $-(x^2+y)$. Therefore the coefficient of $a_y$ in $F_y$ would be 1. Hence there aren't any points at which $F_y=0$.
For $(\mbox{c})$ you will get,
\[2\sqrt{\sin^{2}\pi z +x^2+\frac{100x^2}{(x^2+y^2)^4}}=1\]
This equation gives out all the points at which $|F_x|=1$. I am not sure whether we can simplify further. I hope somebody else might be able to come up with a better solution. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
