MHB Locus in the complex plane.
The discussion focuses on finding the area of the region bounded by the locus of complex numbers \( z \) that satisfy the equation \( \arg \left(\frac{z+5i}{z-5i}\right) = \pm \frac{\pi}{4} \). The relationship can be rewritten as \( \arg(z + 5) - \arg(z - 5) = \pm \frac{\pi}{4} \), indicating a geometric interpretation involving rays and angles. The analysis involves considering the line segment between \( z = 5 \) and \( z = -5 \) as a chord of a circle, with the rays creating a constant angle at their intersection. The resulting shape is identified as a circle with "holes" at the points \( z = 5 \) and \( z = -5 \). The final step is to determine the circle's radius to calculate the area of the bounded region.
juantheron
Area of Region Bounded by the locus of $z$ which satisfy the equation \displaystyle \arg \left(\frac{z+5i}{z-5i}\right) = \pm \frac{\pi}{4} is
Mathematics news on Phys.org
What have you tried?
You can take a geometric approach.
Your relation can be written \arg(z + 5) - \arg(z - 5) = \pm \frac{\pi}{4}, that is, \alpha - \beta =\pm \frac{\pi}{4}.
Consider the line segment joining z = 5 and z = -5 as the chord on a circle and consider the rays \arg(z +5) = \alpha and \arg(z - 5) = \beta subject to the restriction \alpha - \beta =\pm \frac{\pi}{4}. Consider the intersection of these rays and the angle between them at their intersection point. The angle is constant ... Now think of a circle theorem involving angles subtended by the same arc at the circumference ...
It's not hard to see you that have a circle with 'holes' at z = 5 and z = -5 (why?).
Now your job is to determine the radius of this circle and use it to get the area.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
