B Log relationship between thickness of material and sound absorbed?
An experiment on PVC foam revealed a logarithmic relationship between material thickness and sound absorption. The researcher applied the frequency-dependent acoustic attenuation power law, suggesting that sound waves encounter more particles in thinner materials, leading to higher energy conversion. As thickness increases, the likelihood of energy conversion decreases, resulting in reduced sound absorption. The discussion also touches on the exponential reduction of energy as sound propagates through materials. Understanding these principles can enhance acoustic material design and applications.
Marcogoodie
TL;DR Summary
I did an experiement, and found a logarithmic relationship between sound energy absorbed and the amount of mateiral it propagates through. Why is there a logarithmic relationship between the thickness of material and sound absorbed by it?
So I have done an experiment on the amount of sound energy absorbed based on thickness of pvc foam, and found a logarithmic relationship between the two. I've used the frequency-dependent acoustic attenuation power law, which is derived from stokes' law.
Frequency-dependent acoustic attenuation power law:
https://en.wikipedia.org/wiki/Acoustic_attenuation#Power-law frequency-dependent_acoustic_attenuation
My hypothesis is that as sound waves propagate through material, initially, it can bump into more particles and sound waves can be converted into other forms of energy easily, but as the amount of waves decrease when it propagates through thicker material, the chances of it being converted into other forms of energy decrease. Is that correct?
Thanks in advance!
The energy loss, per unit length, is proportional to the energy propagating.
So the energy is reducing exponentially as it propagates.
What is the inverse of exponentiation?
Likes Marcogoodie and SammyS
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
