Longest day of year in the tropics
  • Thread starter bigislander72
  • Tags
    Year
In summary: It is not the summer solstice(june 21) but when the angle of declination(angle sun makes with equitorial plane at solar noon) equals the degree of latitude for that particular location. I calculated that today, may 25 is that for honolulu,hi and will again repeat sometime in july. These are the days the sun appears directly overhead at solar noon. For locations north of 23.5 degrees latitude the longest day of the year coincides with the summer solstice.In summary, the longest day of the year at locations north of the equator coincides with the summer solstice, which is usually around May 25th.
bigislander72
Are these statements correct?
Astronomy news on Phys.org
Not the main claim, no.
Well I have confirmed that my statement was incorrect via this handy website www.srrb.noaa.gov/highlights/sunrise/sunrise.html
I am still confused as to why. It seems that on that day ( approx. may 25) the sun is directley over the latitude for which Hawaii lies and on the summer solstice, the sun makes an arc that is slightly to the north(shadow points due south at solar noon). So I don't understand why the day would be longer. Is this true anywhere in the norther hemisphere?Please explain.
Calculate the length-of-day ( LD ) by
cos(LD/2) = - tan(declination) tan(latitude)
LD is in degrees that can be converted to hours, min, sec
For locations north of EQUATOR the longest day of the year coincides with the summer solstice.
If this is true and if it is also true that the longest day of the year south of the equator is the summer solstice, then it must be that all days along the equator are always 12 hours long. Is this true?
Yes, this is true
Helios -
Not strictly true.
For an arbitrary position on Earth at the Equator given as:
0 0 N 106 35 W - for 2009
May 29 2009 sunrise 06:00:11 sunset 18:07:21 12hrs 7min 10sec
Solstice Jun 20 sunrise 06:04:37 sunset 18:11:53 12hrs 7min 16sec
Solstice Dec 21 sunrise 06:01:21 sunset 18:08:36 12hrs 7min 15sec
The days are very slighty varying in length but the mean time between official sunrise and official sunset are clearly 12 hours 7 minutes and few seconds. Due to the arc subtended by the disc of the sun it is not 12 hours even - sunset occurs when the top of the disc appears, sunset at the time when the "other side" top of solar the disc disappears. The difference is the transit time for the angle of solar disc.
Works out to circa 7 minutes.
Interesting. I remember from my astronomy class that days average longer than 12 hours because of the refraction of the atmosphere, the sun still appears above the horizon even after it has set. Is that the reason for the extra 7 minutes?
partly - it also has to do with how we define sunrise and sunset, too - any part of the sun's disc is visible == we are in daytime.
This is an interesting question - I've had to think about it for a while myself. Here's a suggestion for another way to look at it, which might help:
Instead of thinking about the arc traversed by the Sun as it "moves" across the sky (I admit that I haven't yet found a way to explain the answer in those terms), try thinking about the arc you traverse as your location on the Earth's surface moves throughout the day. If you look at portion of this path that is in the sunlit half of the Earth's sphere, it's clearly half at equinox, and pretty clearly its longest at Summer Solstice, when the path extends the farthest distance past the noon +/- 6 hour angle points to the terminator line. It's a little harder to see what's going on at the days you reference in your OP, but maybe you can convince yourself that it must be shorter than on Solstice.
Well, that would account for two of the seven minutes - one in the morning and one in the evening.
Or slightly longer than 2 if the sun is setting at an angle. I think the remainder of the difference is refraction. Although this varies from day to day, it is not predictable long-term. So the predicted sunset / sunrise times probably use an average which is about 3-4 extra minutes before sunrise and after sunset.
It's called "Lahaina Noon" here in Hawai'i. Lahaina means 'cruel sun', and the name was chosen in a competition sponsored by the Bishop Museum. And YES, we have TWO longest days of the year in the tropics. Here in Hilo, on the Big Island of Hawai'i, those days are approximately May 18th and July 25th.
Related to Longest day of year in the tropics
What is the longest day of the year in the tropics?
The longest day of the year in the tropics is the summer solstice, which occurs on June 20th or 21st in the Northern Hemisphere and on December 21st or 22nd in the Southern Hemisphere.
What causes the longest day of the year in the tropics?
The longest day of the year in the tropics is caused by the tilt of the Earth's axis. This tilt causes the Sun's rays to be more concentrated on the Tropic of Cancer or Tropic of Capricorn, depending on the hemisphere, resulting in longer hours of daylight.
How long is the longest day of the year in the tropics?
The length of the longest day of the year in the tropics varies depending on the location. In general, the closer to the equator, the longer the day will be. For example, in Quito, Ecuador, the longest day is approximately 12 hours and 6 minutes, while in Singapore, it is approximately 12 hours and 13 minutes.
Which countries experience the longest day of the year in the tropics?
The countries that experience the longest day of the year in the tropics are those located near the Tropic of Cancer or Tropic of Capricorn. Some examples include Mexico, India, Brazil, and Australia.
What significance does the longest day of the year have in the tropics?
The longest day of the year in the tropics is significant because it marks the beginning of summer in the Northern Hemisphere and the beginning of winter in the Southern Hemisphere. It is also culturally and historically important in many countries, with festivals and celebrations held to mark the occasion.
  • Astronomy and Astrophysics
34K
  • Art, Music, History, and Linguistics
