Longitude and Latitude to Distances
Calculating longitudinal and lateral displacement from GPS coordinates involves understanding how latitude and longitude translate to distances, which varies based on proximity to the poles. The maximum values occur at the equator, complicating calculations as one moves north or south. A formula for calculating the distance between two points has been identified, but the user seeks to separate this into lateral and longitudinal components. The relationship between the hypotenuse and the angles formed by these components can be determined using trigonometric functions like sine and cosine. This approach allows for accurate calculations of the desired distances.
Hemib
Hi,
How can I calculate the longitudinal and lateral displacement from the longitude and latitude in degrees from a GPS.
Thx!
Not easily.
When it comes to a globe, the values at the equator are at their maximum whilst they tend to zero towards the poles.
You would need to allow for this in order to gain meaningful data. From the outset, it looks rather complex for the purpose you require.
Thanks for reactions!
I now have a formula to calculate the traveled distance between two points. But I want to split this in a lateral and longitudinal distance. So what I have is an right triangle with the calculated distance equals the hypotenuse. What I want are the distances over the other 2 legs of the triangle.
My GPS signal gives me the course I'm heading. Is this the angle in triangle between the hypotenuse and the lateral distance? If it is, I can easy calculate the other 2 legs with sinus and cosinus.
Thx
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
