Looking for a 12VDC motor with low RPM
  • Thread starter Thread starter may ki
    Motor Rpm
A user seeks a 12V DC motor with low RPM (3-10) for a robot's color wheel but finds most available options exceed 3000 RPM and are too noisy. Suggestions include using gear motors, stepper motors, or servo motors, with specific recommendations for quiet motors from printers or cassette players. The discussion also mentions using a square wave to control motor speed effectively. The thread was closed due to a spam connection, but participants provided valuable insights. Overall, the conversation highlights the challenges of finding a suitable low RPM motor while exploring various alternatives.
may ki
I'm looking for a motor that will drive a colorwheel inside a robot. All of the 12v/DC motors I have discovered so far have significantly higher RPMs (3000+) than I require. I would prefer something that runs quietly between 3 and 10 RPM. I looked online and found a few gear motors to try, but the noise is similar to a power screwdriver going on high. There is a lot of transmission noise that cannot be muffled.
I decided to ask a question here because I am a complete electronics novice. I'm unsure of the possibilities available or whether such a motor even exists.
Low torque ? Perhaps a plastic gearbox, or a stepper motor...
Likes russ_watters and berkeman
What the heck, you already have a motor/gerabox you can't use, so try adding some oatmeal to the gear box. (dry, uncooked oatmeal)
If size is not a problem, a motor/gearbox that operates the windows in a car.
Or a servo motor as used in model airplanes or boats.
Likes russ_watters
A motor from a computer printer is quiet in operation. Alternatively, a cassette motor is very quiet and reliable. You can make a motor turn slowly by driving it with a square wave having a mark space ratio which differs slightly from 50%. Use a low frequency, such as 25 Hz, so the motor armature is shaken slightly, as this avoids stiction.
Unfortunately, a connection between the OP and a spammer was found, so I'll close this thread now. Great responses by you folks to the question! :smile:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
