Looking for calculations I could apply to a vacuum-forming machine
In summary: After reading the OP more carefully. Apparently its rated as ##0.3 \, \rm{kW}##.Yes, I have taken a course in Heat Transfer.I think you are going to end up solving something like following differential equation for the time it takes to heat the plastic sheet to its forming temperature.$$ \alpha \frac{dT}{dt} = -\beta T^4 + \kappa $$If you are interested, the details can be filled in.
SaldanaKS
Designing a vacuum forming machine and stuck on creating calculations to supplement the project and aid in proof of design and feasibility. I have done some basic vacuum calculations such as determining the evacuation time as well as a heat transfer calc however I'm not fully confident in their correctness and was hoping to get some advice on any calculations that could be done relating to the vacuum system, heating element, and thermodynamics or the machine in general?
The machine is a simple vacuum forming machine where an aplastic sheet is heated and then drawn over a mold, the vacuum is applied through a platen, and the sheet forms around the mold. Im creating the CAD model however I need to illustrate some calculations based off the design and considering the critical parts.
Any input, suggestions or advice would be much appreciated.
Forming area = 300 mm^2 = size of the sheet
Using a diaphragm vacuum pump
volume to be evacuated = 0.015 m^3
Using a steel rod heating element:
Power = mass x specific heat capacity x change in temp x time
P= 300 W
Rate of heat transfer, Q = 8 J/s
So far I have determined the evacuation time, a basic heat transfer between the heating element and plastic sheet, and a hold down force of the forming bed.
Welcome to PF. :smile:
Could you please define the variables in your "Relevant Equations"? I'm guessing that T is Temperature (in K) and t is time? :wink:
Also, could you please provide a lot more details on your question, including sketches or pictures of your mold and workpiece (including dimensions) and the material that you are forming? Can you post links to the reading that you've been doing so far about vacuum forming?
Finally, just wanting to verify that this is for a schoolwork question and not for your work? I can move it to the ME forum if it is for your work. Thanks.
Thank you, I will update those and try to provide more information and some of my work completed thus far. Its for a university mechanical design project, I wasn't sure which topic that would fall under?
Likes berkeman
You are posting in the correct forum here at PF if it is for a school project. If we need to page in some ME experts at some point who have seen your thread, we can certainly do that. :smile:
How do you apply the heat from the rod to the plastic ?
Maybe use a hot air gun ?
Does the pump need a big capacity, or do you have a vacuum reservoir ?
Using a 220V rod element to heat the plastic, therefore heat would be applied via radiation.
Not sure if a hot air gun would be as effective as a heating element, i have considered quartz and ceramic however.
lastly, the pump is to be as small as possible while being able to have enough suction for the vacuum. Its for a desktop application. So there won't be a reservoir.
Usually the heating elements are rated with wattage? Is it like a ##10 \, \rm{kW}## or a ##1 \, \rm{kW}## heater?
erobz said:
Is it like a ##10 \, \rm{kW}## heater?
Toasty!
pbuk said:
Toasty!
Have you taken a course in Heat Transfer? I ask because heat transfer by radiation is a bit more involved than what you have seemingly computed. There is (at least) the temperature of the emitter to consider (simplest to assume the emitter is a blackbody), the View Factor between the emitter and the absorber (which depends on a number of characteristics pertaining to the physical setup), the emissivity of the absorber (simplest to assume total absorption, not necessarily most accurate), and the thermal characteristics of the absorber to consider. With some (perhaps arguably) reasonable assumptions, I think you are going to end up solving something like following differential equation for the time it takes to heat the plastic sheet to its forming temperature.
FAQ: Looking for calculations I could apply to a vacuum-forming machine
1. What is the purpose of a vacuum-forming machine?
A vacuum-forming machine is used to create plastic products by heating a sheet of plastic until it is pliable and then shaping it over a mold using vacuum pressure.
2. How does a vacuum-forming machine work?
A vacuum-forming machine works by heating a sheet of plastic until it is soft and then placing it over a mold. The machine then uses vacuum pressure to suck out the air between the plastic and the mold, causing the plastic to conform to the shape of the mold. Once the plastic cools and hardens, it can be removed from the mold as a finished product.
3. What factors affect the success of vacuum-forming?
The success of vacuum-forming depends on several factors, including the type and thickness of the plastic being used, the temperature and heating time, the amount of vacuum pressure applied, and the design and complexity of the mold.
4. Are there any calculations involved in vacuum-forming?
Yes, there are several calculations that can be applied to a vacuum-forming machine. These include determining the required heating time and temperature based on the type and thickness of the plastic, calculating the amount of vacuum pressure needed for a specific mold, and estimating the cooling time for the plastic to harden.
5. Can I use any type of plastic in a vacuum-forming machine?
No, not all types of plastic are suitable for vacuum-forming. Generally, thermoplastics such as ABS, PET, and polystyrene are commonly used in vacuum-forming as they can be heated and cooled repeatedly without losing their properties. It is important to consult the manufacturer's guidelines for the specific type of plastic being used in a vacuum-forming machine.
