Looking for help with Thermodynamics
  • Thread starter Thread starter Nora314
    Thermodynamics
In an isolated container divided into two equal volumes, each containing an ideal gas at pressure P, the partition is removed. The final pressure after the partition is removed is P, as the partial pressures of both gases combine to maintain this pressure. The user initially thought the pressure would halve due to the increase in volume but was corrected. The relevant equation is PV=nRT, and the concept of partial pressures clarifies the outcome. The discussion concludes with gratitude for the clarification provided.
Nora314
An isolated container is divided into two equal volumes by partition. In each part of the container there is an ideal gas. They have the same pressure P. The partition is removed. Which of the following is the final pressure:
A: P/2
B:P
C:3P/2
D:2P
PV=nRT (I assume)
Well, I know the right answer is B, the answer key says so, but I am not sure why. I thought about using this equation PV/T = constant, therefore T = PV, and P=T/V, so if volume is doubled, and T is constant, then P will be halved. I am not sure if this is right. Any help? :)
The partial pressure of both gases will be P/2 but the partial pressures add up, resulting in P.
ehild
Thank you so much :D!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
