Looking for resources to help me understand the basics of PDEs for physics
The discussion centers on the challenges of understanding the order and methods used in solving partial differential equations (PDEs) in a math methods course. Participants express a desire for clarity on the intuition behind specific techniques, such as separating variables and using particular solutions. Recommendations for books that emphasize physical intuition and numerical methods for PDEs are sought, with mentions of various university lecture notes available online. The conversation highlights the importance of different solution methods, noting that some are more applicable to specific problems than others. Overall, the need for foundational understanding and accessible resources in PDEs is emphasized.
Philip551
TL;DR Summary: I am taking a math methods course this semester of which a large part are PDEs. I don't understand the context behind the order in which we are solving PDEs. I am interested in learning how other people were taught PDEs and any book recommendations you might have.
What we have done thus far is solve the wave equation for the homogenous case and some non-homogenous cases. The methods we have used are separation of variables and eigenfunction expansions. I am not sure I understand the intuition behind certain steps we are taking to solve the equations e.g. letting the solution u(x,t) = w(x,t) + v(x).
In looking for other books that are available like Farlow and Strauss, I noticed that they use different methods like the method of characteristics and that they don't consider some of the problems we have solved to be important. I would be interested in hearing the order of how other people were taught PDEs, especially in terms of the physical intuition behind certain substitutions and if there are any introductory PDE book recommendations that focus on the physical intuition.
Also, I am also interested in recommendations for books on numerical methods for PDEs.
It is not quite clear what you have trouble with. Order is a bad adjective when it comes to differential equations since it is a technical term. I would definitely search for lecture notes on university servers, e.g. by the search key "Partial Differential Equations + pdf". The "+pdf" part is necessary to end up with actual lecture notes and not on someone's homepage.
My search found:
All these links are in English. You see, that you can find many of them even without violating copyrights.
I found Olver's book a lot, however, I remember that someone here once said that he tends to be a bit sloppy when it comes to details. On the other hand, he is good to read.
In case you have specific questions especially about the "context" of something, then ask in our technical forum
https://www.physicsforums.com/forums/differential-equations.74/
By order, I mean the content that is usually covered i.e. what methods are used, mathematical background topics like the dirac delta function or the Fourier transform etc.
I do not know much about pde's, or physics, but I can still suggest some books you might look at, judging them by their titles, their introductions, and the pedigree of their authors. My impression (from reading the intro to book 1) below) is that there is no general theory of pde's but there are important examples, heat equation, wave equation, and Laplace equation prominent among them. I myself have used the heat equation in my own research in complex algebraic and analytic geometry, and of course the Laplace equation is fundamental to complex and harmonic analysis.
I have on my shelf these two books and suggest them to you for a look;
1) Lectures on Partial differential equations by the great mathematician V. Arnol'd, and
2) Differential equations of mathematical physics, by L. Hopf, an assistant of Einstein.
1) contains far more than 2), and at a far higher level.
Different methods for solving PDEs are useful in different cases. There may be cases where the method of characteristic works well and some cases where it doesn’t. There may be cases where separation of variables works well and other cases where it doesn’t.
As for why we generally have a penchant for teaching separation of variables extensively: it is intimately tied to many concrete physical concepts such as eigenmodes of oscillation or the energy eigenstates of quantum mechanics.
Coming to why we do things like this:
This may seem like a silly approach that does not net you anything. However, the point is typically to separate a more involved problem that you may have into easier subproblems. In this case, u may be the solution to something like an inhomogeneous wave equation. Assuming some inhomogeneoties to be stationary, the ansatz would be to introduce v to be the time independent function solving the stationary problem, thus removing the stationary inhomogeneities from the problem for w. You have likely encountered similar methods in an ODE course, where you have written the solution as a homogeneous part plus some particular solution. The main difference in the example you give is that the particular solution is assumed not to depend on time.
Likes berkeman and fresh_42
Partial Differential Equations by Sommerfeld
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
