Looking to find the amount of energy stored in a clock spring
To calculate the energy stored in a clock spring, the work done to wind the spring can be estimated using torque and the total angle turned, with integration needed for precise calculations due to increasing torque with tension. A simpler approximation involves averaging the initial and final torque values for multiplication. While specific formulas for multi-turn clock springs are scarce, cross-referencing with weight-driven movements can provide insights into energy calculations. The longevity of clock design emphasizes minimizing energy input for daily weight raising. A recommended resource for further understanding is a research paper on coiled springs as power sources.
Willber Force
I'm looking to find formulas to calculate the energy stored in a spring you would find in a clock. I have been having a hard time finding formulas that govern these types of springs. I have found formula in similar springs, such as the spiral-torsion spring found here but I believe this type does not include multiple-turn springs you would find in a clock (I could be wrong).
I understand this is a complex system and any formulas would be approximations anyway. I'm looking to solve an optimization problem using these types of springs so I would like to get something at least in the ballpark if possible.
Thanks for any help that you could provide!
The easiest way might be to calculate the work done to wind the spring: torque needed to turn the winder times the total angle (360 degrees per full turn) it is turned.
The torque is going to increase with the spring tension so this calculation appears to require an integration... but I would bet that the taking the average of the torque when we start turning and when we’re done would be a good approximation, and then we have a simple multiplication.
Willber Force said:
Summary:: I'm looking to find formulas to calculate the energy stored in a spring you would find in a clock.
This is not a specific answer to the question but you could always cross-check your answer against the mgh involved with a weight driven movement. Whilst I realize that clock weights could be heavier than necessary, there is a basis of clock design that it should last for many years so the energy that you put into raising the weight every day needs to be as low as the movement will permit.
I remember an horologist friend of mine telling me that the cheaper the watch, the louder the tick because the spring needs to work against friction. "Ticka tick Timex" was a selling point because you could hear it easily. Timing was not so good though.
A very brief look at Google gave me https://www.researchgate.net/public...source/link/5a9fd5070f7e9badd99f60c1/download. That seems a pretty definitive source.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
